trouble with codes - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-10-2013, 04:43 PM Thread Starter
Quoted: 6 Post(s)
trouble with codes
I started my truck yesterday, well tried. It hadnt run for a few days since i was on vacation. I tried to start it and it would turn over and try but just die. I did it a few times then finally had to jump it. It took a while and some weak batteries but it finally started. It wasnt very cold outside but kinda of chilly. it finally started and i let it run for 45 mins and then put the batteries on the charger. I had some yellow top optimas.
I put 2 brand new batteries.
I put a new FICM relay
My ficm voltage is start 48v, cranking 48, and running 47-48
Battery running voltage is 13.8 volts
I checked grounds and checked cables.
checked ficm fuses.
I replaced batteries , took a a day for the check engine light to come on.
Changed relay and check engine came back on an hr later
Took truck to autozone and they checked alternator and batteries. they said good.
I dont know why i am getting low cylinder voltage on all cylinders.
Is there a way the ficm could be bad, even though all voltages are good?
Ive been searching and trying. I would appreciate any input.
acidbzero is offline
post #2 of 7 Old 11-10-2013, 05:07 PM Thread Starter
Quoted: 6 Post(s)
Oops forgot its 2006 f250 6.0l with 104k
post #3 of 7 Old 11-10-2013, 07:43 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
What is low cylinder voltage?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #4 of 7 Old 11-10-2013, 07:49 PM Thread Starter
Quoted: 6 Post(s)
It was a 0261 code
post #5 of 7 Old 11-10-2013, 08:18 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Ahh did you also have 264 267 270 273 and so on?
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #6 of 7 Old 11-10-2013, 08:25 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
I would first visually check your injector and main harness, sounds like a wire chafing problem if it only happens randomly. The first time the codes came up could have been from the starter draw when you had bad batteries, if the truck drops under 11v while starting the ficm will not fire the injectors and can throw a low circuit code. Your problem can also lie in the ficm as well. But first, remove the injector harness and inspect the entire wire loom and especially the pins for the ficm and injector clips.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #7 of 7 Old 11-10-2013, 08:35 PM Thread Starter
Quoted: 6 Post(s)
I think i narrowed it down to wiring or ficm. Just by what I have been reading.
