PCM - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-10-2013, 03:30 PM Thread Starter
PCM
I have been having a problem with my speedometer will quit working and then the transmission goes into a limp mode it will do this intermittently. Then everything will work as it should. I have checked everything I can. I think the problem is the PCM. This is a 06 E350. I also have a 04 F 350 also with a 6.0. I was thinking about putting the F350 PCM in the E 350 to see if the PCM is the problem. Can I do this switch without burning something up. The plugs look the same I just don't want to ruin my good F350 PCM
Thanks
Lynn 81D is offline
post #2 of 6 Old 11-10-2013, 04:39 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
Econolines are known for wiring chafes around the PCM area. You may want to look at the harnesses in that area more closely
I would not try the PCM swap from the F to the E without programming the module first.
when you lose the speedo do you get various other warning lights on the dash? Do you loose the tach too? I have only had one bad PCM in an econoline 6.0 and it was doing something similar, it was actually losing communication with the other modules on the HS-CAN network, it wasn't affecting the engine running but everything else related to that network was messed up (Instrument cluster and transmission shifting).
The thing that totally sealed the deal was the fact that I had codes for the PCM losing communication with the TCM, since the are both contained in one module it only stood to reason the fault was internal.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 6 Old 11-10-2013, 06:27 PM Thread Starter
When the speedometer quits usually in a few minutes the transmission goes into a limp mode. I lose the communication with my scanner in the 7e9 function. I can still get data readings from the other line. When all this happens the van runs great but if I shut it off it will not restart. This usually happens after the van is warm. Sometimes I can drive 30 miles before it acts up sometimes 5 miles you never know I have changed the speed sensors, there was a chaffed wire in the top of the trans I repaired it but it didn't help. I have tried checking for other bad connection but nothing has helped. I am about ready to pull out the rest of my hair.
Thanks
Lynn 81D is offline
post #4 of 6 Old 11-10-2013, 06:35 PM Thread Starter
I looked at your question again, you wanted to know about the dash. The rest of the dash is normal and the speedo does not go to 0 it will stay at whatever speed I was going when it quit. When everything goes back to normal I have no codes.
Thanks Again
Lynn 81D is offline
post #5 of 6 Old 11-10-2013, 06:37 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
I cannot remember if the one I had would restart after you shut it off. I agree it does sound like a pcm issue but it's hard to say for sure. The PCM definitely communicates vehicle speed to the Instrument Cluster.
If you can read the PCM tear tag(4 digits) you may be able to match it up with one off of Ebay. I see quite a few used 6.0 PCMs on there. I am honestly not sure if you can just go swapping 6.0 PCMs around. There are a lot of different hardware numbers and software calibrations, I couldn't tell you what would happen if you plugged in another one.
I do remember I did finally replicate the concern at the shop while wiggling on the PCM connectors. Even though the fault was internal to the PCM I was still able to move the hardshell around enough to make it happen.
-Matt
2015 F-250 XLT 6.7L
post #6 of 6 Old 11-10-2013, 07:14 PM Thread Starter
Thank you for your input. I will check the wires for chaffing. Where would I need to look is it near the plug?
Thanks
Lynn 81D is offline
