lack of power - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-09-2013, 10:49 AM Thread Starter
lack of power
My brother has an 03 6.0 which has developed a strange problem. During acceleration off the line there is a noticeable lack of power until approx. 50mph at which time it seems to gain power but is followed by a puff of black smoke out the tailpipe and what seems to be a miss from the engine. Also on deceleration there is a series of what we call turbo farts until turbo spools down. He has pulled and cleaned the turbo and the truck is mostly stock. Any idea what could be causing this Thanks
F250 Superduty, Auto, EBPV mod
islandstroker is offline
post #2 of 9 Old 11-12-2013, 07:06 AM Thread Starter
Anyone have any ideas?
post #3 of 9 Old 11-12-2013, 07:33 AM
Heavy_GD's Avatar
Quoted: 1557 Post(s)
Feedback Score: 3 reviews
I'll bite... is he flooring it or easing into it?
Is it his first PS?
How many miles?
What mods? Tuner, sticks, turbo?
Is it lifted, bigger tires?
How old is he?
Google turbo huff.
GD
Heavy_GD is offline
post #4 of 9 Old 11-12-2013, 11:43 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
Sticky vanes or VGT solenoid issue. What does the monitor say about the VGT?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 9 Old 11-12-2013, 01:14 PM Thread Starter
Truck is mostly stock, no tuner or anything. He eases into it off the line normally. He cleaned the turbo and monitor (insight) indicates it is operating properly. Can the MAF cause this issue?
post #6 of 9 Old 11-13-2013, 07:11 AM
Heavy_GD's Avatar
Sorry OP, "mostly" stock tells us nothing and with no monitor you guys are going to be throwing darts.
GD
Heavy_GD is offline
post #7 of 9 Old 11-13-2013, 11:41 AM Thread Starter
As stated in previous post our monitor says everything is running ok...no codes. Mostly stock means no engine modifications.
post #8 of 9 Old 11-13-2013, 04:50 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
If its not building power then you should look at two things seperately- is it building boost quickly and enough boost? Exhaust leak, cac boots and sticking vanes will cause low power without throwing a code.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #9 of 9 Old 11-14-2013, 07:43 AM Thread Starter
It appears to be building too much boost. The turbo was cleaned so that should eliminate the sticking vanes. We have checked boots and they all look good.
