slips right out of 3rd?? - Ford Powerstroke Diesel Forum
Old 08-05-2008, 03:17 PM
so i was on my home from work today and noticed my truck can just slip right out of 3rd gear no problem, like i can just tap the shifter slightly hard but not really and it will go right into neutral unless im on the gas??? is this normal and i just never had it happen before or is somthin happening to my clutch/trans? 04 f250 manual trans. thanks
Old 08-05-2008, 03:23 PM
with the clutch applied?
also if you are getting on it and let put of it and while your rpms are going down it should and if you just tap the gas and at the same time put it into gear, it will drop into 4th and the same for all the rest of the gears
Old 08-05-2008, 03:25 PM
no my foot is no where near the clutch, i just never had it happen before and it scared me lol. so this is normal no problems??
Old 08-05-2008, 04:28 PM
the best i can understand-no problems
Old 08-05-2008, 06:19 PM
cool, thanks man appreciate it.
Old 08-05-2008, 06:30 PM
Um, that doesn't sound normal i dont think
Old 08-05-2008, 06:34 PM
Raging Lunatic
The trannies are synchronized and if you were at just the right rpm and pushed the shifter it could go into neutral.
