4x4/vacuum problem - Ford Powerstroke Diesel Forum
Old 08-02-2008, 11:18 AM
4x4/vacuum problem
I have talked to some friends and read a lot of the forums about a problem with my 04 PSD 4x4, but still have a question. I have the standard response to the defrost/vent blowing ai conditioner test, indicating a vacuum leak, but what's bothering me is the manual hubs. When I put the truck in 4x4 and manually lock the hubs, I still do not have four wheel drive. If there is a vacuum leak, shouldn't the truck be 4x4 with the hubs manually locked?
Old 08-02-2008, 03:25 PM
Update on problem
I just jacked up the front of the truck, put it in 4x4 and manually locked the hubs; only the right front engaged the axle...not the left. Any ideas? I'm thinking hub failure?
Old 08-09-2008, 08:41 PM
I pulled the front of the truck apart today...left, front outer axle shaft is sheared!
