Vacuum pump issues - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-04-2013, 12:27 PM Thread Starter
Vacuum pump issues
So my defrost has been stuck on. I've read a bunch about people saying its just a vacuum leak, but i dont think it is.
I have eliminated the auto hubs, and capped off the hose to them. My blower stays in defrost unless i switch it to 4x4, then it will go back to the vents of my choosing. When i switch it back to 4x2 it still stays at the vents until i switch it to defrost mode, then if i try to switch it back i gets stuck in defrost. Alternatively, if i leave it on vent after doing the 4x4 switch, once i put it in drive it switches back to defrost.
I dont believe the vacuum pump is leaking because it doesn't continuely run, and i pulled the hose off and capped it after the vacuum chamber and it worked as it should. Is their something else that is messing with my blower system?
DTHA is offline
post #2 of 2 Old 11-14-2013, 09:33 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Have you checked the connections going into the heater control knobs. Might just have a loose connection there. Since it changes after switch the 4x4 system I'd say its a vacuum leak.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
