Fuel pump/pressure problem? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-03-2013, 06:39 AM Thread Starter
6pointsl0w's Avatar
Exclamation Fuel pump/pressure problem?
Ok since powerstrokenation doesn't want to reply to my thread ill try you guys. I came across a fuel issue last week. I didn't hear my fuel pump turn on for my truck but it started anyway. Ran really rough, misfired and didn't accelerate on WOT. 10 min after driving it, the pump comes on and everything returns back to normal. I drive it another day and the same thing happens, except this time the truck actually stalled and wouldn't start again, I had to get it towed home. Checked the fuel bowl where the secondary filter is and what do you know, no fuel. And not to mention my battery was dead. So I charged the battery and i have my fuel pump back. The truck ran fine for a week straight with no problems and today I came across the problem again. I'm so frustrated what can it be? All FICM voltage is good so it's not that. Fuel pump? Or some electrical issue? There are NO check engine codes. This truck is my daily driver to school and work so I can't afford to have it down. Please help!
6pointsl0w is offline
post #2 of 5 Old 11-03-2013, 06:48 AM Thread Starter
6pointsl0w's Avatar
Both my fuel filters are also almost brand new with >3,000k on them
post #3 of 5 Old 11-03-2013, 08:30 AM
Well offhand I would say you are looseing power to your pump intermittantly maybe relay or the pump could be failing. Loose wireing, plugin or ground.
Just some things that could be wrong.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 5 Old 11-03-2013, 04:05 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Sounds like a wiring or mechanical issue with the pump. Apparently the relay itself rarelyyy goes bad. Clean electrical connections, clean any grounds in the loop. If you still have problems, replace the pump. Just helped someone on here with the same issues, replaced pump and good as new.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #5 of 5 Old 11-18-2013, 04:00 AM Thread Starter
6pointsl0w's Avatar
Ok so I just replaced the pump last night. Cycled the pump and I get silence. I turn the truck on, it idles like crap for about 10 seconds and the second I gave it the littlest tap of the pedal, it died. I'm totally stumped now. FICM is good, fuse is good, fuel pump is good, what else can it be besides the relay?
Tags
ficm , fuel , pressure , pump
