Oil cooler problem - Ford Powerstroke Diesel Forum
post #1 of 38 Old 11-02-2013, 12:03 PM Thread Starter
lsutigerfanforlife's Avatar
Oil cooler problem
I'm pretty sure my oil cooler is compromised, my temps usually differ around 20-35 degrees when traveling down the highway at 70-75 mph, what I'm worried about is my head gaskets blowing, I have an egr delete so would tha stop my head gaskets from giving up?
lsutigerfanforlife is offline
post #2 of 38 Old 11-02-2013, 07:19 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Possibly. However, if your oil continues to run too hot, it will breakdown earlier than normal and lead to other failures. At some point the oil cooler itself may fail due to thermal difference or corrosion.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 38 Old 11-03-2013, 01:30 AM Thread Starter
Well the truck already runs rough until it reaches about 140-150 degrees, I'm sure it has plenty of problems
post #4 of 38 Old 11-03-2013, 01:34 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I would worry about the oil cooler rupturing and the oil contaminating the cooling system. Coolant hoses don't do very well when oil is run thru them. Plus the OEM water pump has plastic impellers and usually warp or break from they ing to pump a mixture of coolant and oil. As far as your rough running issue... What is your FICM KOEO and running while cold? Have you tried Archoil or RevX? Might be stiction in the injectors as well....
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 38 Old 11-03-2013, 04:20 AM Thread Starter
Well I changed my oil last night, it didn't show any discoloration that I could tell, I have a coolant filter on the way, I tried rev-x before so maybe it's my ficm, which I plan on changing that and the oil cooler soon and flushing the entire system of the ford gold
post #6 of 38 Old 11-03-2013, 11:22 AM
Quoted: 8 Post(s)
Why not get a monitor to verify all your problems… torque app for android phone can be had for under $10 and a cheap Bluetooth/OBDll reader for under $20 would work if your on a limited budget. Since this option exist… the only reason not to have a monitor on your 6.0 is because you don't have a smart phone. Either that or your ignorant just kidding
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 38 Old 11-03-2013, 11:24 AM Thread Starter
I have an Edge CTS and SCT X3, so I know what the readings are unless there is something those don't pick up
post #8 of 38 Old 11-03-2013, 11:31 AM
Quoted: 8 Post(s)
Because you said this I thought you didn't have a monitor… if your FICM volts are below 46v koeo and running cold theN it's your FICM.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 38 Old 11-03-2013, 11:33 AM Thread Starter
I don't have a scan gauge to monitor the volts, I would have to check it with a bolt meter on the screws
post #10 of 38 Old 11-03-2013, 11:37 AM
Quoted: 8 Post(s)
Umm… the edge CTS monitors FICM volts!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
