Loose pitman arm cause death wobble? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-01-2013, 02:15 PM Thread Starter
I have an 06 f250 with 145K. Got it used two weeks ago. Well I have the dreaded death wobble. I read a lot of posts on here, and checked the usual suspects. Ball joints are fine tie rods and everything else look almost new. Then I found this
There is some power steering fluid dripping down. Is this the box going bad? Is it possible the arm being so low has ruined the seal? Should I just tighten the nut and see if this fixes the problem? Could the box be ruined and that would cause the wobble? Like I said everything else looks tight.
When I grabbed the wheel at 12 & 6 it wouldn't move at all. At 3 & 9 it had a lot of play. Also with wheels on the ground truck running, I had a friend turn the steering wheel while I watched it. I didn't see anything shifting out of place.
Thoughts comments concerns?
Lightbulb is offline
post #2 of 8 Old 11-01-2013, 02:58 PM Thread Starter
The tierod has play in it but not side to side. Is that normal?
post #3 of 8 Old 11-03-2013, 04:24 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
I would tighten it for sure!
So is the play in the steering box?
Have someone watch the pitman arm and rock steering wheel back and forth. If there is play adjust it out of the steering box. Allen wrench and 16mm I think, but it's easy to do.
Play anywhere will cause death wobble.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 8 Old 11-03-2013, 09:48 PM Thread Starter
I think the power steering box is the problem.
post #5 of 8 Old 11-04-2013, 02:04 AM
Quoted: 769 Post(s)
IIRC you should not have power steering fluid in there. It supposed to be transmission fluid. PS fluid will tear everything up.
Corey@CNCFAB is online now
post #6 of 8 Old 11-04-2013, 02:11 PM Thread Starter
its not powersteering fluid, I just call it that because it is coming out of the power steering system. But I think my issue is the box, everything else seems solid.
post #7 of 8 Old 11-04-2013, 02:12 PM
Quoted: 769 Post(s)
OK. Just asking because there had been a lot of people on here have put regular PS fluid in their system.
post #8 of 8 Old 11-05-2013, 05:51 AM Thread Starter
Thanks for looking out for me though, this is my first diesel so I've been doing a lot of reading on here. There is a bit of a learning curve
