new guy help already - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-01-2013, 08:32 AM Thread Starter
So just bought my first diesel 2007 f250 6.0 fx4. Truck runs great starts fine cold but when warm it cranks way longer to start. No monitor system on it yet and gonna try to grab a scanguage2 today if possible. But without that is there any idea as to what could cause this? Dealer of course will be no help bought as is they say never go there again lesson learned
jeff52984 is offline
post #2 of 6 Old 11-01-2013, 11:57 AM
ngaraiderman's Avatar
It does it only when the engine is up to normal operating temperatures?
If so this is called a hot start problem. It involves the high pressure oil to fire the injectors. They need at least 500psi to operate. You may have a blown seal in an injector or oil rail or your HPOP may be going out? These are all guessing with out any further info. You need to get some sort of monitor.
ngaraiderman is offline
post #3 of 6 Old 11-01-2013, 12:01 PM
Need to look at ICP voltage. The convert the voltage to pressure and see what your high pressure oil is at while cranking. If you can't get 500psi when hot, then you have an oil leak. Not supposed to post links to other forums so I will PM you a link to the conversion chart. Hopefully someone with way more info could help out also. Good luck. There are also several videos on YouTube that walk you thru checking for a hot no start.
post #4 of 6 Old 11-01-2013, 12:03 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
may also be dummy plugs or stand pipes or STC fitting
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #5 of 6 Old 11-01-2013, 02:22 PM
Yes. Forgot that.
post #6 of 6 Old 11-01-2013, 05:05 PM Thread Starter
appreciate all the quick responses. Well bought the scangauge 2 today and what good is it gonna do when I cant even figure out how to get the info I need or use it lol
