Recommendation on 6.0 upgrades and/or future repairs - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-01-2013, 08:44 AM Thread Starter
Hey everyone,
New to the group and diesel. I am a Jeep enthusiast and haul my Jeep to events with my Truck. Driving a used '05 F250 King Ranch I bought earlier this year with 115K miles and now at approx. 125K miles and have so far changed head studs, added BulletProof Oil Cooler/EGR cooler, SCT tuned and now looking like I just had potential failure of my HPOP. I am aware I should look into an uprgraded FICM module soon. I mostly daily drive it but haul my Jeep and trailer (about 8k lbs) a few times a year. I did research and knew some issues with this motor, but more has come up than I planned.
I am looking for any further recommendations to start preparing for in the near future for failure as my 6.0 continues to nickel and dime me.
Thanks
KingRanch2005 is offline
post #2 of 6 Old 11-03-2013, 04:42 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
If you want it to be dependable don't tune it. I hate to say it but boys and girls but they are tough on the engine. From increased cylinder pressure, higher hpo pressures even the injectors are worked harder. Then of coarse you have exhaust valves/guides operating at higher temps as well.
So I guess my suggestion for you to keep it from nickel and dimeing you would be leave the tuner out.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 6 Old 11-11-2013, 08:14 PM
I'm new here and new to diesels as well. I'm trying to read as much as possible on what mods would be good for my 6.0 and have heard that some tuners (Edge, etc.) can be a problem but others really give props to SCT and custom tunes. I'd definitely like to get better mileage out of my new 6.0 but wouldn't want to do so at the expense of my engine/tranny so please tell me more about the pros/cons of stock vs. tuned.....
Nebraska Outdoors is offline
post #4 of 6 Old 11-11-2013, 10:46 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Tuners have come a long ways since the 6.0 came out.
The 6.0 was one of the first engines completely computer controlled and was a dream come true for tuner companies.
Crank up this and that a Whala you went from 325hp to 500hp. Problem was the learning curve on what it caused to fail and how soon. The more they are pushed the more likely of a failure.
There are tunes that are very stable and not too taxing on the engine. SCT is the favorite for sure for the 6.0. A tune is going to increase hp don't count on a gain in milage it rarely happens. I myself do not feel a tuner is worth the trouble. Now I do have the FICM tune but that's it. There is a small gain on power and fuel milage but only 50hp.
There are tunes out there that people like you might try looking in the performance forum here.
Just know the engine must be healthy before you put a tune on it.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #5 of 6 Old 11-13-2013, 06:15 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Originally Posted by KingRanch2005 View Post
Hey everyone,
Thanks
Tuners and programmers arent the problem! Dont buy a "chip" that screws the incoming and outgoing signals from the pcm, instead get a sct or similar programmer that saves the stock tune and uploads a new tune that better suits your needs- ie daily driver, tow, or performance tune. The most important thing is to monitor your truck with gauges or a monitor so you know when to back off the go pedal. Drive smart and safe on a tuner and the truck will last you, drive around like you stole it pulling a 8k# trailer and your gonna have problems... Even a stock 6.0 will have problems if your drifting every turn and racing cars down the highway and pulling heavy loads... just be smart about it brotha.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #6 of 6 Old 11-13-2013, 07:59 PM
mikemike0409's Avatar
A possible problem that i just ran into is the fuel tank delaminating on the inside and if not caught soon i have heard of people having to replace everything from the fuel tank all the way up to the injectors.
mikemike0409 is offline
