Loosing coolant? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-31-2013, 04:02 PM Thread Starter
kcchief434's Avatar
Loosing coolant?
Well I hope its not what im thinking but im loosing coolant. Its only a little bit but I pop the hood and there is always white spots on degas bottle. I deleted egr about a month ago and oil cooler was good. I also put a coolant filter on. I def do not have the funds to do head studs ill have to trade truck in but truck still runs good. Also I replaced cap and is still doing it. ?? How would I def know if it was a head gasket. I rarely run truck hard and its not tuned
2006 ford f-350 crew cab 4x4 6.0 powerstroke
6 inch lift with 2 inch coil spacer
38/15.50r18 dick cepek mud country
kcchief434 is offline
post #2 of 2 Old 10-31-2013, 06:30 PM
Quoted: 57 Post(s)
There are a couple of ways to determine where you are loosing coolant. One is the EGR cooler, but since you said you deleted the "EGR" I'm guessing that means you deleted the cooler and not just the EGR valve?
External leaks can be water pump, radiator, heater core, hoses, or degas bottle. Assume no visible coolant on the ground?
The degas can puke coolant for several reasons, including a bad cap, warped or partially melted bottle, excessive ECT (boil over), flash boil of coolant in EGR cooler due to restricted coolant flow from oil cooler, or cylinder pressure that makes it's way into the cooling system when head gaskets fail or heads lift under high boost. The later is unfortunately fairly common on unstudded 6.0s, and happens with both tuned and untuned trucks, with low miles and with high miles.
The way to rule out head gaskets is to connect a pressure gauge to the cooling system and then run the truck under load (pulling a grade with a load so turbo boost is >20 psi for a little while). If your head gaskets are toast you will see pressure in the cooling system that quickly reaches and exceeds 16 psi, the vent pressure of the degas bottle cap. My truck would reach 22 psi in the cooling system, but only with the Lance camper loaded and pulling a grade. Fast forward to now, after studs, new head gaskets and the whole 9 yards, and I am monitoring cooling system pressure using my Edge Insight. It generally runs between 4 and 7 PSI.
Hope this helps.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
