HELP! 7 Codes and NO START - Ford Powerstroke Diesel Forum
post #1 of 34 Old 10-31-2013, 05:07 AM Thread Starter
aka MacGyver
rick1067's Avatar
Two weeks ago everything was fine until that Friday. The engine would have a prolonged crank before firing. This went on for a couple of days. When I went to try and start it yesterday, it would crank but no fire. I seen the engine light pop on. I got out my scanner and it returned the following codes in this order; U1900, P0299, P0299, P2291, P0234, P0299, P0299. I have never had so many codes at once. The truck is an 07 F350 DRW 4X4 6.0 with 63,000 miles. I paid FORD $3000 for fuel injectors when it was still under the warrenty period. Now I am having these issues. I am at my witts end.
rick1067 is offline
The Following User Says Thank You to rick1067 For This Useful Post:
RedneckYankee (12-03-2013)
post #2 of 34 Old 10-31-2013, 05:31 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Well, I don't understand why it shows the p0299 code 4 times which is an under boost code. The p0234 code is an over boost code, neither of which will cause the no start. U1900 is a communication fault. I suppose that could be an issue but not sure. P2291 is the one you need to start investigating. That is a low ICP code while engine is cranking. The ICP has to be a minimum of 500 psi for the engine to start.
dhanna6powerstroke is offline
post #3 of 34 Old 12-03-2013, 06:12 AM Thread Starter
aka MacGyver
rick1067's Avatar
Ok Thanks for the info. I will have to go get an ICP. Are there any upgraded ones better than a stock one from FORD?
rick1067 is offline
post #4 of 34 Old 12-03-2013, 06:41 AM Thread Starter
aka MacGyver
rick1067's Avatar
This weekend, I will be replacing the following items;
1. Replacing the EGR Cooler with an EGR Delete Kit.
2. Upgrading the Turbo Feed Line.
3. Disassembling, cleaning, lubing and reassembling the Turbo.
4. Upgrading the Stem Pipes and Dummy Plugs.
5. Upgrading the Oil Cooler.
6. Upgrading the STC Fitting.
7. Replacing the IPR Screen.
8. Replacing the High Pressure Pump Filter Screen.
9. ICP Sensor
10. Replacing the IPR Switch.
11. Replacing the Air Filter.
12. Replacing the Fuel Filters.
13. Replacing the Oil Filter.
rick1067 is offline
post #5 of 34 Old 12-03-2013, 06:50 AM
RedneckYankee's Avatar
Have you tried to unplug ICP to see if she'll start? If it does then it would be the ICP. If it doesn't it may be the IPR. Both times my 05 Ex had an ICP fault code it was the IPR.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #6 of 34 Old 12-03-2013, 06:59 AM Thread Starter
aka MacGyver
rick1067's Avatar
Thanks you, Sir. Ok will give that a try first.
rick1067 is offline
post #7 of 34 Old 12-03-2013, 05:52 PM
Mod Newbie
Quoted: 19 Post(s)
Also, with it being an 07, it should already have the upgraded drain tube.
post #8 of 34 Old 12-03-2013, 06:05 PM Thread Starter
aka MacGyver
rick1067's Avatar
Are you refering to the drain tube on the bottom of the turbo?
rick1067 is offline
post #9 of 34 Old 12-03-2013, 07:39 PM
Mod Newbie
Quoted: 19 Post(s)
Yeah, the turbo drain should already be the updated one.
post #10 of 34 Old 12-04-2013, 10:36 AM Thread Starter
aka MacGyver
rick1067's Avatar
Do you know of any other upgrades that were done to the 07 model year?
rick1067 is offline
