ECT & EOT Deltas - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-28-2013, 02:28 PM Thread Starter
ECT & EOT Deltas
Hey y'all I have a 2004 F-250 6.0 and I just installed an EGR delete on it this last week. I'm noticing now that when I first start driving my truck before it's up to operating temp the ECT is about 13-15* warmer than the EOT. It used to not be this high. Once the truck gets up to around 175* though they're staying about 5-8* apart from there out. I know that a 15* delta is the threshold for telling if your oil cooler is bad but I wasn't sure if it makes a difference whether the EOT or ECT is the higher temp. Just wondering if this is normal or if this is the sign of a failing cooler. Thanks!
Tx2va07 is offline
post #2 of 3 Old 10-28-2013, 03:08 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
When I had my OEM oil cooler set up my oil temp would lag behind the coolant temp as well. I dont beleive this is anything to be worried about.
Heck it even does it now with my bullet proof set up.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 3 Old 10-29-2013, 08:37 AM Thread Starter
Thanks man, that makes me feel better!
Tx2va07 is offline
