Heater cold - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-25-2013, 07:12 PM Thread Starter
Heater cold
2006 F250 4x4 6.0 powerstroke with climate control. As truck warms up( have a chip so I am watching coolant temp) it gets to 125 degrees or so and heater starts to blow. Cold air now, used to be luke warm. as the truck warms up air is still cold until around 210 then the thermostat opens and heater blows hot. within seconds the coolant goes back to 172 degrees and heater blows cold until thermostat opens again at 205 to 210. blows hot again until cools down to 180 and does it again. usually four times it does this until the temp stabilizes around 190 and then the heater blows hot until you go down a big hill and engine cools to below 175 blows cool until temp comes back up around 190. Thanks
hwhound is offline
post #2 of 9 Old 10-26-2013, 06:33 AM
Term3's Avatar
First thing I'd do is replace the thermostat.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 9 Old 10-26-2013, 08:12 PM Thread Starter
I have twice, went from original and put in new one. I hadnt payed as much attention to the coolant temp until putting new one in. Decided the new one was suspect because of the 210 before opening so replaced it under warranty again, same results. The thermostat never opened until at least 190 before but still had warm air from heater as truck warmed up so I think it is something else. Thanks
hwhound is offline
post #4 of 9 Old 11-01-2013, 12:19 AM
hdodt's Avatar
I had a similar issue...my temps stayed fairly even around 180 but couldn't get heat. Found my heater core was clogged...it's a $60 fix and really quite easy...there's a good "how to" video on YouTube. It's easy to check. Drop your glove box down and remove the heater core cover. With the truck warm feel the heater core. Mine was hot on top cold I the bottom. Or you can feel the heater hoses going to and from the core. The one with the vacuum valve is the in...it should be hot, the other should be about the same temp if not the core is clogged...I just replaced it since it was a cheap part, I guess you could back flush it though.
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #5 of 9 Old 11-01-2013, 12:27 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
your heat core is plugged and once the thermostat open wide enough the coolant is forced the the clog in the heater core but quickly looses its heat once the flow stops from the thermostat closing. You might look into a coolant filter. How are your ECT vs EOT temps by the way? Its rare to have a heater core plug without the oil cooler plugging as well but maybe you got lucky or its a newer oil cooler.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 9 Old 11-01-2013, 12:53 AM
hdodt's Avatar
My oil cooler plugged up a few months before the heater core. I'm wishing I had replaced the heater core when I did the oil cooler/coolant-elc flush....
2006 F350 Lariat
hdodt is offline
post #7 of 9 Old 11-05-2013, 07:13 PM Thread Starter
I think you are right on the spot. My EOT is running hotter than should and this summer my ECT started running hotter than it used to. I was getting ready to replace my oil cooler and do a EGR delete. I am getting exaust gas in coolant. I haven't ever got it too hot so hoping don't need to get into head gaskets. Thanks for info, I had my suspicions about the plugged heater core and was pretty sure about the plugged oil cooler.
hwhound is offline
post #8 of 9 Old 11-06-2013, 04:39 AM
Term3's Avatar
If your EOT is hotter than it should and your getting exhaust gas in the coolant you probably have a ruptured EGR cooler. So the exhaust gasses tend to collect in the cooling system high points, the degas bottle AND yout heater core. This basically partially vapour locks the heater core until the water pump is spinning fast enough to push out the vapour which is probably a mix of exhaust gasses and steam since there is a very low coolant flow going thru your EGR cooler and the coolant is being boiled by the exhaust gas going thru the EGR cooler. I wouldn't leave it too long as exhaust gasses in the coolant break it down and makes your coolant corrosive.
Term3 is offline
post #9 of 9 Old 11-06-2013, 08:34 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
My 6.0 did what sounds like the same thing....ended up bing bad hg's
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
