first 6.0 need some help - Ford Powerstroke Diesel Forum
post #1 of 16 Old 10-25-2013, 05:38 PM Thread Starter
Quoted: 2 Post(s)
So I just bought my first diesel about 2 months ago 06 KR f250 with 204k when I bought it and it was a very very well maintained truck and was told by the previous owner who bought it new that all he had done was clean the egr valve at about 150k and that was it, I have done a lot of research on the 6.0 and these things can be tricky once you start having issues so here is my question, I make a 2600 mile trip every 2 months or so unloaded and have done this twice so far, the first trip it died in the middle of nowhere but ended up being the egr valve, right before my last trip I noticed when I started it I saw a bit of blue smoke bit it went away pretty quick then after about an hour of driving around I got out to load some things in the back and let it idle for about ten minutes when I took off I noticed it blowing a good amount of white smoke which it has never done before and it hasn't done it since, could this be the ficm? I also noticed on my last trip after about 21 hours of non stop driving I started to hear a very slight miss at idle and seemed that there was more engine noise then normal, I went to show my buddy after about an hour of it sitting and it fired right up and ran perfect, I've also noticed when its warm it cranks a little longer maybe 3 full seconds before it fires, I have some ideas but I've done some research and can't seem to find anyone having this same issue, any advice would be much appreciated
dslpwr06 is offline
post #2 of 16 Old 10-27-2013, 10:37 AM
I think it's your IPR valve. I had same issues and it ended up being that I had a puncture in my IPR screen. Go ahead and buy an IPR socket at a local auto parts store, unbolt degas and push out of way, unbolt and take out ficm, and then you should have access to the IPR. Pretty easy to do.. - Mike
dobronos is offline
post #3 of 16 Old 10-27-2013, 04:29 PM Thread Starter
Quoted: 2 Post(s)
Thanks I'll give that a try
dslpwr06 is offline
post #4 of 16 Old 10-28-2013, 04:46 PM
White smoke... thats water vapor in the exhaust. Possible he needs to check his deltas for possible clogged oil cooler and possible bad egr cooler?
Im a diesel noobie soaking up as much info as I can before I go out and look for my oil burner next year. My diagnostic sense is tingling on this one, if the oil cooler hasnt be replaced recently, I think that you should have that checked out as well.
Im definitely going BPD when I get my 6.0.
lexustech48 is offline
post #5 of 16 Old 10-28-2013, 05:25 PM
KCCO!!
kells17's Avatar
OP, do you have a monitor on the truck to check your delta's? If no, get one ASAP. If you're starting to blow smoke, sounds like a possible blown oil cooler/egr cooler. Not saying it's not possible, but if all the PO did was clean the EGR valve in 204K he's a lucky guy or gal. If you are having hot start issues, need to find out if you're stand pipes and dummy plugs have been replaced/updated. As Mike said too, check your IPR and make sure the filter is in tack. Good luck and get back with us.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #6 of 16 Old 10-28-2013, 05:28 PM Thread Starter
Quoted: 2 Post(s)
Its definitely not coolant cause I haven't lost an ounce in the 8000 miles I've driven it since I've had it and coolant would be a constant white "smoke" or steam rather then just temporary and when I pulled my egr valve and cleaned it out it was bone dry in there so its not that, its something with the hpop or a sensor I'm lead to believe, hoping its not an injector or 2, but with that being said you will love the 6.0 they are a very well built truck and as long as you are anal about maintenance it will treat you right, I absolutely love mine
dslpwr06 is offline
post #7 of 16 Old 10-28-2013, 05:37 PM Thread Starter
Quoted: 2 Post(s)
I actually almost ordered some dummy plugs and stand pipes the other day just for the heck of it cause they are pretty cheap and from what the previous owner had told me everything on the the truck is stock and I just read up on the update for them, and I have no idea what the IPR stands for or what exactly it does, I guess I must have got a good one though he told me he ran Howes with every tank of fuel and changed all filters at 5k along with the oil, well I won't be able to get to it till Wednesday at the earliest but I'll let you know if I come up with anything good
dslpwr06 is offline
post #8 of 16 Old 10-28-2013, 06:47 PM
From my understanding, IPR is the injector pressure regulator. Its that valve thats on top of the HPOP and regulates the HPO pressure.
Current: 2002 F-250 XLT SCLB 4x2 V10 (yes.... it devours gasoline like an alcoholic at a wedding)
Future: 6.0 Super Duty 4x4
post #9 of 16 Old 10-28-2013, 07:33 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
You need to get yourself a monitor. most common are:
scangauge 2 its best to buy from bulletproof diesel since it has all the 6.0 codes already in it.
edge insight cs or cts for about double the price but has some goodies and extra monitoring options.
both plug into the obd2 port. it would be the single best thing for a 6.0.
once you get a monitor post the following temps under full operating temp while driving:
engine oil temp
engine coolant temp
ficm volts
ipr
icp
also good idea to post some reading when cranking.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #10 of 16 Old 10-29-2013, 03:29 AM Thread Starter
Quoted: 2 Post(s)
An edge insight was going to be next on my list of things cause it makes me slightly nervous driving all those miles not knowing what's going on under the hood, and also with the IPR would I just need the o rings and screen or the whole valve?
dslpwr06 is offline
