Truck wont start after injector replacement - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-24-2013, 08:46 PM Thread Starter
SAILOR97's Avatar
Hey guys I am in desperate need of some help. I am so dissapointed. I replaced all 8 injectors rebuilt by warren diesel 155/stock and replaced the FICM from BPD 4 phase. I really took things so slow with installing and believe I followed all the directions and steps. I'm just bummed the truck wont start it turns over and I can smell diesel out the pipe. I checked the FICM voltage and its good at 48.7 with a volt meter. I'm just beside myself I dont know what to do. I hear clicking louder than normal on the passenger side of the truck but I had the hood open and am not sure if it was that loud normally before the injector rebuild and I might be paranoid and grasping at straws. I really dont want to take it to a mechanic and give up but just dont know where to go from here. Im an aircraft mech in the Navy and really like working and doing on my own stuff I also replaced with the upgraded 1 piece stand plugs and the dummy plug. So that is everythig I have replaced on it with this job. Thanks for any help ahead of time, just feeling defeated
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
post #2 of 13 Old 10-24-2013, 08:53 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
You sure all injector harness are plugged in? Did the ficm harness click when you seated them?
Its got to be something simple
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 13 Old 10-24-2013, 08:59 PM Thread Starter
SAILOR97's Avatar
well I checked the FICM voltage on top and with the key on it registered 48.7 and all the harness i pushed them on and installed the clips...It did seem when pluggin them in there wasnt a click and didnt seem really tight but i made sure there were pressed in tight. thanks for the help though I'm willing to try anything
SAILOR97 is offline
post #4 of 13 Old 10-25-2013, 10:53 AM Thread Starter
SAILOR97's Avatar
Does anyone think something could of failed since pressure was off the system?
SAILOR97 is offline
post #5 of 13 Old 10-25-2013, 10:56 AM Thread Starter
SAILOR97's Avatar
Also my edge isn't registering any FICM volts but when I check the FICM with a volt meter its 48.7
SAILOR97 is offline
post #6 of 13 Old 10-25-2013, 11:05 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
If you didn't fight a little to get them back on and click, they are probably not making good contact. Also, give a light tug on your injector plugs to see if they are connected as well.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 13 Old 10-25-2013, 11:19 AM Thread Starter
SAILOR97's Avatar
OK...I will look at that again....its got to be something with that then...on the edge my ficm sync is 0 and my ficm volts is 0 and after looking or should say listening I'm only hearing the injector clicking on the passenger side
SAILOR97 is offline
post #8 of 13 Old 10-25-2013, 11:30 AM
Beewoody's Avatar
X2 it's likely at the Ficm
05 F-250 SD Crew Cab Lariat 6.0 PSD: BPD Oil Cooler, BPD Manual Fan Clutch Adapter with 7.3 fan, Built FICM powerboard w/Atlas 40, Gearhead's SRL, 8k Tow, Unlimited Tune, EGR Delete, Blue Spring Mod, 6.4 Banjo, Updated HPOP/STC, Updated Standpipes/Dummy Plugs, EC-1 ELC Coolant, Updated Turbo oil supply/return lines, Edge CT, 2.5" Readylift Level Stage 3, 35/ 12.5/ 18 TOYO AT2 Extems' mounted on 18" MB wheels and finally.... STOCK HEAD GASKETS
.... 203K miles on 10/3/2014...
Beewoody is offline
post #9 of 13 Old 10-25-2013, 11:36 AM Thread Starter
SAILOR97's Avatar
Crap...OK I'll check that again...I already did it twice...that thing is a monster to take in and out guess I'll just pull the degas bottle and intake again cause from what I'm hearing that seems to be the likely issue
SAILOR97 is offline
post #10 of 13 Old 10-25-2013, 02:38 PM
Quoted: 43 Post(s)
Now that is a bit of an exaggeration! Yes, the plugs can be awkward to click in unless you get your hands positioned correctly. But as I said, no click, no work! Check for damaged pins this time, just in case!
The degas doesn't have to be completely disconnected, just the bolts and the 2 small hoses. Just pull it to the side on its edge and you should have no drips. If you have some plugs, that could help if it moves. If the hoses go low, they will leak fluid.
Frank
Working for Toys
