hpop\oil cooler\egr delete issues - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-22-2013, 07:52 PM Thread Starter
I had my hpop replaced in my 05 F350, tech said it need a new oil cooler\egr cooler. After reading this forum I asked tech if he would do an egr elete. He said he couldn't do it but if it was his truck thats what he would do. I understood and found another local shop to do the delete and oil cooler. Picked truck up from 1st shop($2k) it ran fine but was told not to drive it much until oil cooler and egr were taken care of. I ordered a egr delete kit\oil cooler and a fuel pressure regulator kit, tool truck and parts to new shop, 2 days later called and said it was done. Started right up and idled fine, slight humm from engine compartment that wasn't there before, i figured egr delte would change sound some. Drove it 3 miles it was ok at first then smell of exhaust.. parked for for a few hours the started it back up, idled fine then erratic throttle, racing, choking. Got it home with it running extremly rough and strong exhaust smell in cab. Next morning went to start it(20 degrees outside) started very rough with exaust filling engine compartment, obvious exhaust leak. Took back to shop and they say now the exhaust leak if fixed but still runs like crap. Runs fine for a little while then rough as it warms up, especially when you take foot off gas after getting up to speed. Shop is lost on what is happening, no codes, they are leaning toward oil pressure issue. Super frustrating!!!
steamboat_springs is offline
post #2 of 17 Old 10-22-2013, 07:56 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Do you have a monitor? You need to check icp volts, IPR duty cycle %, FICM volts.... Then report back. Check all these things with the motor cold KOEO (key on engine off) and then right after you first start it, and then again after it's completely up to operating tempature idling and last but not lest check all those thing at WOT near max rpm. FICM volts only matter when truck is cold because they normally increase in volts as the truck warms up if they are low to start with.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 17 Old 10-22-2013, 07:57 PM
Quoted: 8 Post(s)
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #4 of 17 Old 10-22-2013, 08:07 PM Thread Starter
Tech says ficm is fine and had monitor hooked up during test drive and nothing came up? I will suggest this to him in the morning. It is getting a little testy between him and I as I was the one who found the exaust leak and printed a page from the forum on how he needs to fit the turbo\y pipe properly. I'm afraid he is over his head. Thanks for the input.
post #5 of 17 Old 10-23-2013, 05:38 AM Thread Starter
He also steamed\power washed the engine compartment to look for oil leaks, maybe that unconnected something?
post #6 of 17 Old 10-23-2013, 07:48 AM
Quoted: 8 Post(s)
Get your own monitor. Some can be bought for under $200. It's a most of all 6.0 owners! I'm talking about either a Edge CS/CTS or older insight, dashboss (iPhone compatible), torque app (android compatible), AutoEnginuity.. Etc...
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 17 Old 10-23-2013, 07:53 AM
Quoted: 8 Post(s)
I doubt it unplugged something it it's possible a sensor got moisture inside it. It might not dry out without being unplugged and blown out with air but no one can give you advice on where to proceed with more information on the engine vitals... So get a way to view the motors sensors and let us know. I can't stress enough how important a monitor is even when there isn't a problem with the motor! Get one ASAP!!!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #8 of 17 Old 10-23-2013, 08:57 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Doesn't sound like you are sure the mechanic you chose to do the work is familiar with the 6.0...
If he isn't, The first thing that pops into my mind is that he probably wasn't as clean as he needed to be when he did that oil cooler replacement.
If just a little piece of garbage got below the HPOP reservoir screen in the bottom of the cavity that the oil cooler sits, that junk was sucked up by the HPOP and then shot (under close to 4000psi) right into the face of the IPR valve. If this is the problem, you just need to pull the IPR and replace the screen. Don't remove the screen, clean it and put it back on, buy the rescreen kit from a Ford dealer.
If that screen has a pinhole in it, there is a chance that some garbage got into the IPR itself. That would require that the IPR be replaced.
This is where I would start.
Please
You could save the life of a sick child
NYC F-350 is offline
post #9 of 17 Old 10-23-2013, 10:12 AM Thread Starter
Thanks, he is taking it over to the local Ford Dealer to see if they can figure it out now. I will mention it to him. .
post #10 of 17 Old 10-24-2013, 02:29 PM Thread Starter
The tech now is going to replace the ipr screen, if he(Tech) is going that far should he replace the ipr itself? How much is a new IPR.
