05 excursion 6.0 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-22-2013, 05:43 PM Thread Starter
05 excursion 6.0
Replaced ficm with new bulletproof half . The truck ran for two days before blowing fuel pump fuse for the first time replaced fuse and the truck still won't start. Had no problems before replacing ficm other than low circuit voltage to the injectors. Cranked several times for 30 sec. to prime but still won't start.
70 bronco is offline
post #2 of 7 Old 10-22-2013, 05:57 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
Hmm..wondering if fuel pump is dead. Any idea what caused to to blow the fuse? That probably doesn't just happen for no good reason. That being said, I'm not sure how to diagnose that.
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #3 of 7 Old 10-23-2013, 02:08 AM Thread Starter
I don't know why the fuse blew but I can
Here the pump running and the second
Filter canister is filling up with fuel.
post #4 of 7 Old 10-23-2013, 04:57 PM Thread Starter
I call bpd and they had me send the hole ficm to them to test.
post #5 of 7 Old 10-26-2013, 06:18 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Thats weird that the fuse blew at the same time the ficm is having issues. I have a feeling that blown fuse has something to do with the no start, not the bpd ficm. But, interested to see whats the problem.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #6 of 7 Old 10-28-2013, 01:30 PM Thread Starter
BPD called today and said they bench tested and tested it on a test truck it failed both test. They replaced the power/logic (bottom half) and the test truck started and run fine. They are thinking the blown fuse is another issue. BPD ISN'T going to charge me the $150.00 for the bottom half I just have to pay for shipping.
post #7 of 7 Old 11-01-2013, 04:11 PM Thread Starter
I received the ficm back from BPD and installed back on the vehicle
And the truck started right up. I took it for a 30 mile ride and it run just fine.
