Stand Pipe Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-19-2013, 04:21 PM Thread Starter
Stand Pipe Question
I have a 2005 F-250 Lariat 6.0L. Latley i have been unable to start when hot. I have an edge insight and when cranking hot I am getting about 350psi ICP so no start. I disconnected the ICP sensor and no start. So I figured I would replace the STC connector, and the standpipes and dummy plugs. I got the parts today and when I took the passenger side standpipe out it has a 1/2 square head and is only about 2 inches long. The two replacement stand pipes are about 9" long (6E7Z-9A332-A). Are these the right replacements for both sides? If so how the hell do you get them past the evaporator? is there another piece in the engine I need to get out? The part number for the dummy plugs is W302908, is that right? Thanks for the help.
stevens157 is offline
post #2 of 3 Old 10-19-2013, 06:42 PM
twoicebergs's Avatar
Quoted: 42 Post(s)
You need to reach in and pull the bottom piece out. If you can't get it out, you will need to remove the oil-rail to get a hold of it. When you go to put the new one in, there are a few methods. You can separate the new standpipe, and insert it in 2 pieces but I wouldn't do that. The easiest way is to loosen the oil-rail and insert the stand-pipe while refitting the oil-rail. You could also remove the cover to the AC unit.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 3 Old 10-19-2013, 06:58 PM Thread Starter
Thanks
I figured out that there is another piece in there. Thanks. I have been fixing gas vehicles my whole life and this is my first diesel. Get a little freaked out sometimes because I feel like an idiot.
