Fuel gauge problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-19-2013, 04:24 AM Thread Starter
Fuel gauge problem
Several times now, when i get in my truck and start it, the fuel gauge will go to full and the electronic miles to empty gauge will also sho about 475 miles to empty when there was actually about half tank of fuel. Sometimes it corrects after several minutes of driving. Lately it seems to be getting worse and sometimes doesnt correct. Anybody have this happen? What do I need to do guys?
briancox51 is offline
post #2 of 4 Old 10-19-2013, 09:44 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Sounds like the fuel level sensor in the tank is going out. Usually it will fail to empty tho. Might have a short, dirt or grime in one of the connections going from the sensor to the pcm.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 4 Old 10-19-2013, 09:58 AM Thread Starter
Thanks. I assume that sensor is in the tank? Is there a way to check the wiring? Maybe clean it? Do I need to drop the tank to do that?
post #4 of 4 Old 10-20-2013, 06:09 AM
ford fanatic's Avatar
It's a common problem, my truck does it sometimes too. Some claim that running Diesel Kleen helps the problem, i've been running it for a while and it has seemed to help.
If it is the sensor itself, i've heard it is about $600....so I just fill up every 350 miles.
06 F150 Scab 4X4
05 Ranger 4 banger beater
13 Explorer Sport (wife's)
Powerstrokes Sold...
E99 Reg Cab 6 Speed
02 Scab 4X4 Lariat
06 CCSB 4X4 Lariat
ford fanatic is offline
