School me on water pumps - Ford Powerstroke Diesel Forum
post #1 of 42 Old 10-18-2013, 12:32 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
So I noticed the truck has a small puddle of water/coolant on the ground and some coolant splatter that's dried white on the inside of my hood. Pretty sure this sounds like a water pump but wanted your opinion before I buy anything. I also wanted to know what happens if you overfill your degas, is that what causes the weep hole to start leaking? Also I've read through the how to on how to replace the water pump and it seems unnecessary to remove the radiator, or am I wrong? I'm debating getting the bpd pump or the diesel site pump, input on both would be appreciated. Anything else I should do while I'm in there? I'm going to do blue spring update, new belt, and flush then refill with ELC. Thanks for any and all input
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #2 of 42 Old 10-18-2013, 04:14 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Nothin?????
6.0newb! is offline
post #3 of 42 Old 10-18-2013, 04:22 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Sounds like you overfilled your degas bottle and it puked. (A bad water pump wouldn't cause white residue on your hood, but a decent amount of puking out the degas cap could.)
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 42 Old 10-18-2013, 04:28 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
There's no puking from the cap, no white residue or nothin. Didn't drive the truck for a day and it still drips a drop once every 10 seconds roughly. Whole bunch of white residue on the axle and some on the factory stabilizer
6.0newb! is offline
post #5 of 42 Old 10-18-2013, 04:33 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Well, THAT does sound like a water pump. I'm running the BPD water pump, so that's what I would recommend, but I don't have any experience with the DieselSite water pump nor have I heard from anyone who is running one.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #6 of 42 Old 10-18-2013, 04:33 PM
mossyoak's Avatar
Ch
all the bullet proof things done, cat antifreeze, stock sticks, powermax / batmowheel, Tony Wildman tunes.
mossyoak is offline
post #7 of 42 Old 10-18-2013, 04:35 PM
mossyoak's Avatar
Check your radiator the plastic top and bottoms will leak around the crimps bad design
mossyoak is offline
post #8 of 42 Old 10-18-2013, 04:36 PM
Quoted: 58 Post(s)
If you need a water pump, go BPD. Once and done.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #9 of 42 Old 10-18-2013, 04:46 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Kinda what I was thinking...
So does the radiator absolutely have to be removed? And once I put the fan clutch back on, how tight do I go with it?
Thanks so far fellas
6.0newb! is offline
post #10 of 42 Old 10-18-2013, 06:12 PM
Term3's Avatar
Quoted: 2 Post(s)
Once you have lifted the rear half of the fan shroud and fan/clutch out at once changing out the water pump is super easy. Just take the top rad bolts out so it can be moved just a touch. I'd check the steel tube that supplies the heater core where it attaches to the front cover, seen it leak at that O-ring a couple times. Don't forget to disconnect the fan clutch wiring harness.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
