Massive Smoke, Loss of power, limp mode, NO CEL... - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-18-2013, 06:14 AM Thread Starter
Coleo's Avatar
Quoted: 2 Post(s)
Exclamation Massive Smoke, Loss of power, limp mode, NO CEL...
Ok so here is the chain of events... Leaving work around 5:15pm temp outside is about 45F and I start up the truck and let it idle for about 5min. I take off up the road set cruise to 60MPH on flat ground go about 6 miles up the road and then there is sudden loss of power, massive smoke coming out of exhaust. take off cruise, try to give the pedal some throttle, nothing feels like limp mode. So I turn off the engine and coast to an approach (side road to field). There is NO CEL (check engine light)!!! So I wait to turn it over for bout 2-3 min. I turn it over and still lots of smoke no CEL and no power with some throttle. Turn off again, I wait longer, open hood and look for a boost tube that is blown, oil, anything... Can't find anything that would cause limp mode and no power and a ton of smoke out exhaust. So I close the hood hop in the cab, dig out the AAA card and think well let's try one more time. I fire it up and everything is back to normal! no smoke, no weird idle, I have power, I rev it and it seems normal, no CEL!
I heard of a similar story but it was related to another 6.0L, where the EGR was stuck open or some odd position and the very same thing happened, but that person had his intake cleaned professionally and there were pebble like build up that was causing the EGR not to move and it was similar.
I just had an oil change and fuel filter change (both filters). This oil change I put in Hot Shot Secret. I run Stanadyne in the tank all the time. Just not sure what it was that caused the smoke and loss of power.
Any thoughts?
Cole
04' 6.0L F-250 SuperCab Short Bed
ARP Head Studs
Edge Insight CTS w/Pyrometer
BulletProofDiesel Oil Cooler Kit, BPD EGR, BPD FICM 48v
Ford Head Gaskets, Upgraded Standpipes, Turbo feed & drain tube, Blue Spring Fuel Upgrade
Banks Turbo back Monster Exhaust, Banks TechniCooler, Banks RamAir Intake
MotoMetal Rims on Goodyear's DuraTrac’s
2nd factory turbo (quiet version 13 vein)
Shell Rotella T6 Oil, Shell Rotella Ultra ELC
Coleo is offline
post #2 of 2 Old 10-19-2013, 09:49 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
What color smoke?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
