6.0 powerloss until warm - Ford Powerstroke Diesel Forum
Old 07-15-2008, 04:59 AM
Good Morning,
My 2005 F250 6.0 has an issue! When ever it sits over night and I go to leave for work the next morning it starts and runs fine, but when I take off down the road it doesn't have alot of get up and go, it runs about 2500rpms at 40mph. Within a couple of miles and everything is warmed up it runs like a new one. It's like the rpms will rev up but the truck isn't going as fast as it should for those rpms. Anyone have any suggestions???? Thanks!
Old 07-15-2008, 05:21 AM
I don't have any suggestions, but my work truck an 04' is the same way.
Old 07-15-2008, 05:24 AM
How long have you had this truck? The truck is designed to hold back on power until the trans gets warmed up.
Old 07-15-2008, 05:29 AM
I've only had it about 2 months.....It's my 1st PSD and I am no expert on them!..Thanks for any help!
Old 07-15-2008, 05:33 AM
I'm guessing it could be normal, cause it doesn't smoke or run bad at all other than the warm up. Guess I could be just trying to go before it is warmed up enough..
Old 07-15-2008, 09:30 AM
You need to get a scanner and run a buzz test and a cylinder contribution test. Injectors can usually act up when its cold.
Old 07-15-2008, 09:32 AM
Rob Rob is offline
mine is that way, i just let it run for 5 minutes or so before i leave. its real bad in the winter too.
Old 07-27-2008, 04:52 PM
mine did the same thing..had 2 bad injectors. wouldn't get out of it's own way till it warmed up. watched some ford tech videos from this site and then went to the dealer the vids said injectors and so did the dealer.
Old 07-27-2008, 05:00 PM
i'm guessing injectors....find a good tech, perhaps NOT the dealer. (not saying dealers are bad, just syaing if you arent getting the answers you want, its ok to look elsewhere.)
Old 07-27-2008, 05:07 PM
mine did the same thing .....took it in and had then flash it with all the new stuff and its great now ....i have power right away
