No power from turbo, could it be MAP sensor? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-17-2013, 06:41 AM Thread Starter
First off, this forum is awesome. I've spent about 20 hours searching and reading threads and I'm starting to get a hold of what this engine is all about. I'm no mechanic, but I've done my fair share of work on all my vehicles. Here is what I have going on:
2003 pure stock.
Symptoms: no power from turbo, shifts fine, runs fine downhill, but going up hill barely crawls.
I've already checked and/or eliminated as possible causes: Turbo (it's a new turbo, can't hear any leaks out of any hoses, CAC, cic.
On the scan gauge I'm getting fine FICM voltage, good icp, good vgt.
HOWEVER, the scan gauge shows -1.3 boost at all times, and 11.3 MAP at all times. I'm thinking this could all be the MAP sensor.
Would a bad map sensor cause the no power from turbo issue?
Would a bad sensor cause there to be a constant reading of 11.3 on the scan gauge?
I've spent a lot of time and cold nights on this thing, but I think I'm getting close. Thanks in advance.
volleyjiver is offline
post #2 of 5 Old 10-17-2013, 07:20 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
After the first time I had my turbo out and back in I had a couple leaks and it just killed the turbo. And later I also found a very small leak on the egr valve its self. Have you had the system apart?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 5 Old 10-17-2013, 07:39 AM Thread Starter
Yes, I've had it apart a few times. Each time with new seals.
How can I go about finding any leaks around the turbo? I don't hear anything, definitely can't see anything.
Is there a way to test/check for leaks?
post #4 of 5 Old 10-17-2013, 08:34 AM
While leaks are the most common cause of boost issues they aren't the only causes.
Out of range readings from a number of sensors can cause the pcm not to command the vgt solenoid properly. Physical problems with the turbo rust carbon build up that can make the unison ring stick or vanes stick.
Any one of these can cause problems.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 5 Old 10-19-2013, 09:53 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
With truck off, koeo look at map and baro. Should be identical readings. If they are, take the map hose off and use a paper clip to clean the nipple coming off the intake, and clean the map hose. It could be plugged. If they arent identical, then your map sensor probs needs to be replaced
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
