Another 6.0 No Crank No Start Probem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-16-2013, 02:20 PM Thread Starter
Hello. I have a 2004 6.0 w/auto tranny. I recently replaced the starter a couple days ago. The problem was that I could hear the bendix kick out but would not crank the engine. I think this was due to my GPR controller going out and over excessive starting. Replaced the GPR controller a couple days before I replaced the starter. After that the truck started better than it ever had. It was consistent half a second to 1 second start times. This morning I went to crank it and it cranked about a half a second then just quit cranking while the ignition switch was in the start position. Now nothing. Pulled starter on truck and bench tested it...works. It sounds like I blew a fuse in the middle of cranking, but I have checked the fuses under dash and all good. The Haynes manual I have has a wiring schematic in the back but the whole book is a crude excuse for a service manual if I ever saw one. The diagram is for a 2002 Diesel. It shows fusible links and a couple central junction boxes, but I cant find either on mine. It still has all the dash lights and bells as it normally has. It sounds like something so simple, but I am about to pull out my hair. Can someone please HELP me? Thanks!
puna.skeeter is offline
post #2 of 3 Old 10-17-2013, 01:46 PM
jello's Avatar
Have you checked for power down at the starter?
Check the main big wire first so you know the connection to the battery is good at least.
2003 King Ranch 6.0
MBRP 4" turbo back no cat
SCT by gogodiesel(direct injection performance)
jello is offline
post #3 of 3 Old 11-19-2013, 07:21 AM
Quoted: 8 Post(s)
What was the culprit?
2005 F250 FX4 6.0 PowerStroke, Dashboss, Swamps 58V FICM, PHP Atlas 40 tune, Tony Wildman Extreme Tune, IPR Coolant filter, ELC Coolant, EGR....nevermind, updated stc, more to come!
Babyboy70363 is offline
