Crank no start 2006 6.0 need help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-15-2013, 06:09 AM Thread Starter
Boozer76's Avatar
Trcuk is at stealership. Unfortunately I just don't have time to wrench this on my own with a baby on the way and work I'm doing around the house for the baby. Truck ran fine yesterday, never had any cold or hot start issues at all. Engine temp was 60 degrees when I tried to crank since it's cooler out these days. Let glow plugs cycle and cranked, turned over fine but did not try to actually start at all, just constant crank. FICM voltage was at 47.5 at crank, ICP was 40-50 with key on, went op to 1900 or so when cranking. In my haste I did not check IPR % or disconnecting IPR sensor. The stealership called and said they watched the oil pressure in the dash while starting and said it was not registering any oil pressure. I don't believe them since I clearly saw plenty of pressure when it was cranking. Just need advice on what to watch for since I know these guys are going to try and rake me over the coals. No oil leaking anywhere that I could see.
My Album
Currently stock engine 52k miles.
4.5" Icon lift kit
Rockcrusher front and rear diff
Procomp A/T Extreme tires
full tint on all windows
Blue Spring Update
SCT tuned, canned performance for now
Straight pipe MBRP Turbo back exhaust
XDP EGR delete kit
Boozer76 is offline
post #2 of 2 Old 10-15-2013, 11:05 AM Thread Starter
Boozer76's Avatar
Cam position sensor. It threw that code too on my Edge, should have mentioned that in my original post. I had read that code comes up often if you crank for long periods of time so I dismissed it, but they changed it out and truck started no issues. Hooray for easy fixes.
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
