Truck shakes when cursing and falls on it's face when I hit the petal - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-14-2013, 05:44 AM Thread Starter
Ok guys just got my truck all back together everything is new from the heads up using diesel site hpop, warren 190/100s and when I'm just cruising around town or highway at 45 to 60 at around 1200 to 1700 rpms truck shakes and sputters and falls on it face till I get over 2000 rpms, I have a regulated return and my fuel pressure is staying at 65 and I use t6 oil and it's new fuel
Jeremy
2004 Black&Gray F250 Harley Davidson Crew Cab 4X4
MODS:
6" all spring lift & dual front shocks with 35 NITTO's, MBRP SS cool duals, Harley Orange Ford emblem, ARP studs & OEM gaskets, Adrenaline HPOP, All Ford updates, Owner built fuel system and RR, Owner build trac bars, Warren Diesel 190/75s, MTW hybrid, SCT liverwire ts with IDP tunes & IDP FICM programmer, Sinister Diesel coolant & bypass filter kit, Elite Diesel coolant crossover kit, 07 Harley lights & 6k HID's, Electric Fans
JBowen747 is offline
post #2 of 6 Old 10-17-2013, 10:14 PM
It really sounds like an bad Injector, had the same problems with my truck at the same rpm's. Guys on this site pointed me in the right direction when my truck started doing that, take it and have it scannned maybe. Hope this helps and if it ends up being something different let us know these trucks are difficult at times to find the problem. Mines was number three injector replaced it run great a month later number 4 went, stuck open alot of smoke it was easy to figure out that time cause the pyro temps went down when in unplugged it, it had a cracked tip
BP-1 is offline
post #3 of 6 Old 10-18-2013, 07:07 AM
4506.0's Avatar
Your sig doesn't say anything about EGR delete. Any chance it's stuck open?
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
post #4 of 6 Old 10-18-2013, 07:24 PM Thread Starter
It's deleted and truck got worse and started smoking white to black but it was fuel an not coolant then I got a code for cylinder 1 so Patrick at warren diesel over nighted me a injector and I'm going to pull it tomorrow and from talking with him it might of came loose or I didn't have it seated right so it's prob something I messed up and I thought that was great of them to send me one like that , amazing customer service
Jeremy
MODS:
post #5 of 6 Old 10-19-2013, 03:06 PM Thread Starter
Egr cooler and valve are both deleted I got a cylinder one contribution code after I changed the oil and took it for a drive and it puff white and started Rolling a lot of coal so I called warren diesel and they think I had a hold down come loose on a injector or did seal good so I'm going to take it apart and check them all out and the push rods and rockers just to be safe and do compression test
Jeremy
MODS:
post #6 of 6 Old 10-19-2013, 03:12 PM Thread Starter
I got a cylinder 1 contribution code after truck got worse and truck is puffing white then black as soon as ya go above idle and it's fuel for sure warren diesel told me I might of had a injector not seated right or had the hold down come loose but they over nighted me a new one ...amazing customer service! and the egr valve and cooler are deleted ,I will tear back into it and check compression an all the push rods while I'm at it to just to be safe
Jeremy
MODS:
