06 6.0 help please - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-13-2013, 07:53 PM Thread Starter
06 6.0 help please
I need help my truck is having major issues. The truck will crank over and over then start it will rev up then shut down like I turned the key off. I hear the injector buzz when I turn the key on. The other day before this it started running really rough like it had a miss. I run the airdog 2 it's getting fuel to secoundary housing on motor. I was winding could it be the crankshaft sensor or cam sensor. If you need and more information I'll tell you everything I can. Any help would be greatly appreciated. Thank you josh.
Oh almost forgot there are no codes being thrown
Joshs6.0 is offline
post #2 of 5 Old 10-13-2013, 08:08 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Do you have a monitor? If so what is your ficm voltage? What is your icp reading? Ipr?
Check this out No start issue? Look here.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 5 Old 10-13-2013, 08:27 PM Thread Starter
I don't currently have a monitor right now, I was looking into the ae software, I tried unplugging the icp sensor but no change. I'm going to do the voltage on ficm tomorrow. The pump on my airdog went out two weeks ago and I put the new one in and it ran great for a week then one day it started bucking and the turbo was making a lot of boost when in park and reving. So I shut it down returned the ECM back to stock, came out the next morning to go to work and it turned over and over fired up rev'd then died. In January I had an egr delete, updated sct fitting and head studs installed. And new ipr
Joshs6.0 is offline
post #4 of 5 Old 10-16-2013, 01:15 PM Thread Starter
Just an update, went out today to mess with the truck a bit, charge the batteries and turned the key over and the injector buzz sounded but it was like 2 then half the third then nothing. Could my ficm have died or half the board
Joshs6.0 is offline
post #5 of 5 Old 10-16-2013, 01:20 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Until you get a monitor your just gonna be guessing what the problem is.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
