Truck running hot towing. Little help please - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-13-2013, 04:16 PM Thread Starter
cj1026's Avatar
Quoted: 5 Post(s)
So this weekend we took out the new trailer for the first time.
We went 47 miles. First 10 or so flat stop and go threw town. Then we got to the hills. Same area I drive to go to work.
Normally I see Ect at 190-192 and Eot of around 180-188 we driving to and from work.
With the trailer (5200 lbs) I was seeing Ect at 216-218. At one point both Ect and Eot reached 226. Only for a minute or a bit less. The truck did puke a little.
I recently replaced the degas tank, cap and thermostats all with Oem when I did my oil cooler.
After we got to the camp site we unhooked and the truck sat for about 20 minutes until I realized I forgot my water hose. Idiot. So went to get a hose. Truck would warm up to Ect 216 then drop to 208, then warm up to about 216 again. Eot stayed around 188.
I'm thinking water pump but looking for any ideas you guys might have.
2005 F350 Lariat CCLB 4x4 FX4
ARP Studs
BPD EGR Cooler, Remote Oil Cooler, 58v FICM, Water Pump, and 7.3 Fan Mod
Mishimoto intercooler pipes and boots
Mishimoto radiator
Mishimoto 202* Thermostat
SCT X4 with tons of tunes
Power Hungry FICM tuner
Edge CTS2
Blue Spring and Zoodad
MBRP Y Pipe
MBRP 4" Exhaust
S&B CAI
Riff Raff Turbo Wheel
DC Power 185
Nitro 4.10 gears and Eaton TrueTrac
6" Lift, Bilstein 5100 with 35" Toyo MT's
cj1026 is offline
post #2 of 3 Old 10-13-2013, 04:28 PM
If you are reading these values with a scanner or some type of monitor in the morning turn the key on and read the values they both should be within a few degrees of ambient.
One of your sensors are out of range possibly. useually oil temps are higher than coolant temps yours are reversed.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 10-13-2013, 04:34 PM Thread Starter
cj1026's Avatar
Quoted: 5 Post(s)
I reading temps on a scangauge. My temps will be different running the BP diesel oil cooler I do believe.
ARP Studs
Mishimoto radiator
Edge CTS2
MBRP Y Pipe
MBRP 4" Exhaust
S&B CAI
DC Power 185
cj1026 is offline
