Really need some help with my 6.0! - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-13-2013, 04:00 PM Thread Starter
Hello, I am new to the forum. Ive learned a lot of valuable info from this site. So here is a little background on my problem. I bought a 2004 f350 with a 6.0 about a month ago. It had a really rough idle when first started and the seller told me all 6.0's are like that. It also had a dead go pedal when coming off the highway or at random times the truck would just die and stall out. It got worse so I took it to dealer and they diagnosed 6 out of 8 bad injectors. I had a friend of mine replace all 8 with ford reman injectors. My rough idle went away and the dead pedal and stalls stopped! Then after a week the engine would idle rough at random times even when warm! It would act as if it was choking out or like it was hiccupping. If I turn truck off and restart it will start up and idle fine? Im confused on why it will idle rough and then if I turn it off and back on it runs fine?? Oh, and Im also getting the dead pedal and stalls sometimes. Ive replaced all filters and fluids, and the icp and icp harness. I added a video to show how it runs when its choking out. Thanks. - Mike
Edit: you really can't hear how its choking out in the video. It is not running good in the video though, is there anything that the gauges read that looks like it might be causing the problem?
dobronos is offline
post #2 of 18 Old 10-13-2013, 04:12 PM
Tennessee Powerstrokes
GoFastPadre's Avatar
It could still be injector issues or possibly the ficm. I would get a Buzz Test done and check the voltage on the ficm. My truck had very similar issues and the thing that straightened it out was two bottles of REV X The best $72 I have ever spent.
To reach GoFastPadre
Official Chapter Area
GoFastPadre is offline
post #3 of 18 Old 10-13-2013, 04:29 PM Thread Starter
Buzz test was done and read fine. My ficm never drops before 47.50 volts. Did you use the Rev x fuel or oil additive?
dobronos is offline
post #4 of 18 Old 10-13-2013, 04:40 PM
I use the oil additive I use Shaeffer oil's fuel additive. There are other good fuel additives out there I am sure, but only one rev x oil treatment. Beans Diesel Performance had the best price I could find on it, but be sure to check the sites sponsors first. Hope this will solve your issues.
post #5 of 18 Old 10-14-2013, 03:30 AM Thread Starter
Truck started fine this morning. I let oil warm up to about 150 degrees F. Started down road and truck just stalled. Started right back up and then continued down road. Another 1/4 mile and then it stalled again. Started back up again and then I made it to work. any ideas???
dobronos is offline
post #6 of 18 Old 10-14-2013, 05:56 AM
PHYRMN's Avatar
Whats the IPR reading when cold, and when fully warmed?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #7 of 18 Old 10-14-2013, 07:47 AM Thread Starter
Can the SCT LiveWire monitor ipr? I didn't see an option for monitoring it? I may be wrong though..
dobronos is offline
post #8 of 18 Old 10-14-2013, 05:02 PM
Wolf Diesel Performance's Avatar
you can see it threw injection control pressure (ICP).... are you pulling any codes ? and do you have a tune on the truck ? Also if you wanna try some Rev X let us know !!!
Wolf Diesel Performance is offline
post #9 of 18 Old 10-14-2013, 05:19 PM Thread Starter
I am running a tune from More Power Diesel. The truck acts the same with or without the tune. The idling got worse, and it kept stalling. Ended up dropping it off at dealer. I will let you guys know what they say tomorrow. Here is a video of how it was idling..
dobronos is offline
post #10 of 18 Old 10-19-2013, 07:07 AM
I would definitely be interested in what you find out. My 06 acted very similar last night.
CoalRoller06 is offline
