No injector buzz but truck started fine - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-13-2013, 06:36 AM Thread Starter
Soledad's Avatar
Garage
Last night when I started the truck up for the first time after it had been sitting for 48 hours I noticed there was no injector buzz. The temp outside was about 58* and my ScanGauge-2 showed FMP at 47.0V which is a hair low but it's almost always showing 47.0V-47.5V. This is the first time I've never heard it except the time when I pulled the relay to load the FICM tune on it many months ago.
Any way, the truck started just fine and ran like it always does. No stiction issues, no smoke unless I'm hard on it and no misses.
Does the injector buzz on KOEO just not happen from time to time?
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #2 of 8 Old 10-13-2013, 06:54 AM
PHYRMN's Avatar
I would take a more in depth look at the FICM. How old are the batteries and have they been load checked lately?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 8 Old 10-13-2013, 07:04 AM Thread Starter
Soledad's Avatar
Garage
Thanks PHYRMN. I was just going out to go check that and look to see if any silent codes have popped up. I'm hoping the PO dated those batteries but if he didn't then I have no clue how old they are. But they certainly aren't the stock batteries. I have noticed just a bit of corrosion on the driver side positive battery terminal so I may clean all of those up today.
Plus I'm going to check to see what kind of batt voltage I'm getting at KOEO and what it reads for FICM input power.
Soledad is offline
post #4 of 8 Old 10-13-2013, 10:29 AM Thread Starter
Soledad's Avatar
Garage
Well, no codes and I got injector buzz each time I turned the key on. And the batteries are dated Nov 2012. Soooo, I guess I'll clean up that one battery post and keep an eye on FICM input and main power.
Soledad is offline
post #5 of 8 Old 10-13-2013, 02:04 PM
PHYRMN's Avatar
Ok, good deal.
PHYRMN is offline
post #6 of 8 Old 10-15-2013, 09:13 AM Thread Starter
Soledad's Avatar
Garage
Was getting the oil changed and asked them to do a load test on the batteries. The right side battery failed big time. I wonder if that's why I didn't hear the injector buzz that one time? Truck has been starting and running fine though.
Soledad is offline
post #7 of 8 Old 10-15-2013, 09:40 AM
On a 6.0 sometimes you will not hear the injectors buzz not shure why.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 8 Old 10-15-2013, 09:40 AM
PHYRMN's Avatar
The powerstroke electrical system is very dependent on both batteries being in tip top shape. Having a failing battery could cause a myriad of problems, especially with the FICM.
PHYRMN is offline
