running bad when cold. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-12-2013, 04:54 PM Thread Starter
I have a 2004 f250 and when I start it in the mornings and start driving it doesn't make any power and won't let go of first gear until it warms up. Any thoughts. By the way it does it even when its not cold outside.
04fourwheeldrive is offline
post #2 of 9 Old 10-13-2013, 09:47 AM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
FICM, fuel injectors or both
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 9 Old 10-13-2013, 09:52 AM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
What about the High pressure oil pump?
My business truck is doing the exact same thing as the OP and I have a good FICM.
It could easily be injectors, but I just started thinking what if it's HPOP
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 9 Old 10-13-2013, 09:56 AM Thread Starter
I hear there's a computer flash that includes the inductive heating upgrade would that help? Because once it warms up it runs fine.
post #5 of 9 Old 10-13-2013, 10:03 AM
Quoted: 364 Post(s)
How bad is it when it's cold?
Mine chugs and smokes blue/ black and won't go anywhere even if I floor it for a good 5-10 min.
I don't think that update will help you if yours is anything like mine!
Studded and Deleted
post #6 of 9 Old 10-13-2013, 10:28 AM Thread Starter
Mines not that bad it just doesn't really make any power. It doesn't smoke.
post #7 of 9 Old 10-13-2013, 10:55 AM
capcalvin's Avatar
Sounds like injectors to me.
'03 F350 6.0 CC dually lariat 4x4
Autometer gauges:
Pyro, boost, fuel pressure
Edge insight cts
Bulletproof EGR cooler (Blocked off)
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Exhaust: MBRP 4" cat back with delete pipe
SCTx3 Tunes by Innovative and Gearhead
Swamps 58v FICM
High idle mod
SRW front wheel conversion
ARP head studs
capcalvin is offline
post #8 of 9 Old 10-13-2013, 11:43 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
No, I would recommend NOT to do that upgrade! If I am correct that is one of the main causes that leads to killing your trucks FICM.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #9 of 9 Old 10-14-2013, 05:00 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
FICMs fail quite often on trucks that don't have inductive heat. They also fail on trucks that do have it. If you have injector problems cold then you really should consider the latest strategy. I went back to a non-heat strategy last winter and it made it 10x more apparent I had failing injectors.
-Matt
2015 F-250 XLT 6.7L
