FICM voltages during driving - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-12-2013, 11:49 AM Thread Starter
So today I was driving and watching the dashboss particularly the FICM Voltage, and I noticed that it would fluctuate from 46-48 volts, should I go ahead and have one on standby in the event that this one crashes or should I be okay with this voltage?
I have new batteries and a new alternator so the input voltage isnt a factor. I have dealt with for some time now a slight "miss" during cold running conditions which only lasts about 4-6 miles.
Stiction or FICM, would FICM replacement or repair, fix the slight miss on cold starts?
Any thoughts or suggestions...
cjw13cjw is offline
post #2 of 3 Old 10-12-2013, 11:55 AM
Term3's Avatar
Have you upgraded your batteries cables and cleaned your grounds down to bare metal?
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 3 Old 10-12-2013, 12:08 PM Thread Starter
I did not replace or upgrade the cables as the ones on there are in good shape, I did clean the grounds with wire brush. I am reading good input voltage 12.5 with switch off, and I think its around 15 when running. The only fluctuation I see is the FICM output voltage and it is constantly moving around between 46-48 volts.
cjw13cjw is offline
