6.0 Liter no start no crank - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-11-2013, 04:34 PM Thread Starter
I'm new to the site with a big problem. After washing the engine with a water hose. A day later it would die going down the road. A couple days later on a trip to north AL. the truck stopped running seven more times at speed. Some times it would start right back after I stopped and put it in park. The other times at KOEO all dash lights come on but the water in fuel light engine will not crank. Like the battery is dead. I get out move the wiring harness under the hood. This time KOEO water in fuel is on and engine will crank and start.
Started looking for wiring harness issues. Unplugged the PCM center plug had liquid on it. Pulled PCM and could hear liquid inside. Placed PCM on its side it appears to be oil coming out of it.
In the mean time the tow haul light started flashing. Now has no overdrive.
I got a PCM from Ford. Took it to the dealer to have it installed. Was told by the tech the PCM was not the problem. It need a FICM, FCIM wire harness, EGR valve, Transmission solenoid. I let them replace the transmission solenoid. Which did not fix the trans. Was told I needed a new Transmission.
I think the liquid in the PCM is causing the problem with the trans and the no start no crank.
Sorry so long. I need some help.
I don't want to spend $4200.0 on a trans and not fix the problem
Dblack045 is offline
post #2 of 4 Old 10-11-2013, 05:34 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
If you have water in the PCM or the FICM you need to get that fixed or dried out ASAP, without applying power to the units. Do not proceed with any diagnosis until you know the status of the PCM and FICM.
It also sounds like you may have a Vref short or open circuit. What codes have you seen?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 4 Old 10-12-2013, 01:14 AM
I agree matter of fact you may want to buy a hair dryer [saves a hassel with the wife] and just start unplugging every plugin you come across and start drying them out.
If ya got water in one your bound to have soaked others. FYI pull the battery boxes there there are a bunch under the drivers side battery box.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 4 Old 10-12-2013, 08:30 AM Thread Starter
It does not appear to be water. It feels and taste like oil. I had it out of the truck for 2 day with it on its side to drain. A small amount of liquid drained out of the 3 plugs. The truck still cranks and runs. I'm trying to figure out where the oil came from in the first place. Is there a capacitor in the PCM that could have split opened and drained into the PCM or did it get in thru the wire harnesses. And is this oil in the PCM causing my problems with the no crank and the transmission problems.
