Over the weekend as I was driving about 30 mph my truck shut off abruptly as if the key was turned off. I tried starting it and it would run for about 5 seconds and shut off again. There were no lights on, no trouble codes, no smoke, nothing... At about the 5th time I tried starting it it ran for about 2 minutes and shut off again. Then I waited 10 minutes, started her up and its been fine ever since! I'm thinking it was maybe the fuel filter got clogged? I have nooo idea what to think, if maybe I should bring it into the dealer anyway?
It's been running fine ever since Saturday.Your input is greatly appreciated! |
cps??????????
If it is the CPS, it should have set a code. Won't necessarily show a light though. Don't see a whole lot of problems with the CPS in the 6.0.
no,but that does not mean that they dont go.
never seen a cps on a 6.0 go bad , maybe one that i thought it may have been a possibilty , but then it even turned out not to be and was a internal ficm problem, sounds like fuel pressure , or maybe an icp sensor if its early production 04
mine is just starting to do that also it does not stop the truck but when driving every so often it acts like a miss or shutting off the fuel supply
Installed new filters and a pressure gauge but I don't think fuel is the problem also had a problem when pressing the peddle the truck would just Idle (played with the conections on the fuel pedal and throttle body and that has not happened again |
Sorry about that. Didn't mean to imply that it wasn't or couldn't be the CPS. Just saying that you don't see them. I was a shop foreman at a Ford dealership for 2 years and never seen one bad.
