Running out of options - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-05-2013, 03:12 PM Thread Starter
Alrighty fellas im running out of options here, i bought this 04 f350 about amonth ago, it ran fine, well i did an oil change and changed the fuel filters and it started right up after that, the next morning i go to start it and it started horrible super rough start and really rough idle till it warmed up. Come to find out i was 5 quarts short so i added the 5 quarts and no change, so i went with the fact its just the first start of the day that it has a really rough start and idle till warm so i assumed it was the ficm bc i pulled a p0611 code well the ficm is good i have the 58 v so it keeps the code on, i had a hole in the rubber coupling to the turbo hose so i replaced that, then just replaced all 8 glow plugs bc it also pulled a few bad glow plugs, 2 brand new batteries and brand new EGR valve. im hoping its just stiction, is there anything else that it could be, im gonna try rev x and see what that does
Diesel_trucker is offline
post #2 of 8 Old 10-05-2013, 03:47 PM Thread Starter
and also Doesnt shoot any smoke at all
post #3 of 8 Old 10-05-2013, 03:57 PM
Lilfarmrboy's Avatar
What kind of oil did you use? How did you check your FICM (Running, key on, cranking)?
Lilfarmrboy is offline
post #4 of 8 Old 10-05-2013, 04:36 PM Thread Starter
I use 15w 40 rotella with mc filter, I was thinkin about switching to syn, but thats almost a hundred buck so I will if I have to, and the ficm.I sent down to texas to ficm fixer and they installed on there truck and tested it and it put out 58 v koeo and 57.5 cranking and started
post #5 of 8 Old 10-07-2013, 02:13 PM Thread Starter
I still cant figure it out, im about to change to syn and try some rev x but idk if its gonna help
post #6 of 8 Old 10-07-2013, 02:19 PM
usnavyad's Avatar
Feedback Score: 3 reviews
How is your injpw
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #7 of 8 Old 10-07-2013, 03:13 PM
midnite rider's Avatar
Quoted: 285 Post(s)
my sons 05 did similar thing put t6 rotella in it , then took it for a drive and ran it like stole it. truck is running fine now
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #8 of 8 Old 10-07-2013, 03:25 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Sounds like classic stiction to me. there was a really good how-to thread on cleaning the varnish from the spool valves on the injectors..
Fixing stiction
you may give that a shot. It beats the cost of revX
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
