Injector bore brush D94T-9000-D - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-04-2013, 11:57 PM Thread Starter
SAILOR97's Avatar
Hey was wondering if anyone has a way of cleaning these injector bores out? These 2 brushes are over 100 bucks is there another way or brush that I can use to clean the bores and thread out. I have the injectors pulled and shipped off to Warren for rebuild right now and these 2 brushes are just too expensive for a one time use or hopefully not for another 100,000 miles. Thanks guys
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
post #2 of 6 Old 10-05-2013, 10:02 AM
Believe it or not a baby bottle brush works just about as well you just have to use it for a little longer until it comes clean and the stiff nylon brisstles wont scar the walls of the injector cup.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 10-05-2013, 10:03 AM Thread Starter
SAILOR97's Avatar
Dannyboy...awesome idea thanks man
SAILOR97 is offline
post #4 of 6 Old 10-05-2013, 02:12 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
6.0 injector cups are stainless. Usually whatever oil/fuel will wipe right out. If you've got a copper washer failure you should consider replacing that cup.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 6 Old 10-05-2013, 02:46 PM
How do you know if you have copper washer failure and is this something you should replace when doing injectors
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #6 of 6 Old 10-05-2013, 04:02 PM Thread Starter
SAILOR97's Avatar
No copper washer failures...so I'm good there
SAILOR97 is offline
