white smoke - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-04-2013, 05:00 AM Thread Starter
perez700r's Avatar
white smoke
Why does my truck still smoke white after arp headstuds and bulletproof egr cooler? It only smokes white when cold but only on acceleration but clears up is the motor warms up. Starts up just fine in the morning.
perez700r is offline
post #2 of 4 Old 10-04-2013, 06:47 AM
southend's Avatar
Could be residual moisture in the exhaust system etc from failed egr and head gaskets. How bad was your egr and head gaskets prior to replacement? How much have you run it since the rebuild? Other than that it could be a sign of overfueling.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 4 Old 10-04-2013, 08:15 AM Thread Starter
perez700r's Avatar
It's been about 2 days since the heads and egr replacement
post #4 of 4 Old 10-04-2013, 11:18 AM
southend's Avatar
I would just keep an eye on it and if it doesn't clear up soon, you may have overfueling issues. Check your oil frequently to see if the level rises. Overfueling is not a good scenario. You really need a monitor to check for codes, and ficm voltages. Check out the sticky on monitoring.
southend is offline
