crank, but no start HELP! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-03-2013, 05:24 AM Thread Starter
Truck turned over but wouldn't start or fire at all this morning. Last Friday my alternator went out and I drove on just battery power for 30 minutes. Truck ran fine all week until today, now nothing. I assume its a fuel problem, I heard low voltage can damge the FICM. Might this be the problem? Or is there something I should check before that? Please help asap, this is my only vehicle, and I'm hitching a ride to work as of now. Thanks everybody!
Captain Wacky is offline
post #2 of 11 Old 10-03-2013, 07:21 AM Thread Starter
And yes, I just realized there is a "click here if no start" thread at the top of this forum.
post #3 of 11 Old 10-03-2013, 01:15 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Yes low voltage can kill ficm. Test the ficm voltage koeo and cranking. Test everything else in the sticky and report back with all your numbers
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #4 of 11 Old 10-03-2013, 04:17 PM Thread Starter
With battery on, putting 47.5 volts. With engine cranking putting out between 47.5 and 48.5 volts... Checked my fuses, no CEL's...
post #5 of 11 Old 10-03-2013, 04:22 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Any codes?
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #6 of 11 Old 10-03-2013, 05:22 PM Thread Starter
Nope, no codes.
post #7 of 11 Old 10-04-2013, 04:46 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Any drivability issues before this? Check out ur icp and ipr values. Make sure you have pcm and ficm sync. Make sure you have 4.9v reference voltage. Try unplugging sendors on vref circuit one at a time
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #8 of 11 Old 10-04-2013, 10:15 AM Thread Starter
No issues before this really. Replaced the alternator last Friday. Tuesday morning it turned over for 5 seconds before starting, usually starts in 2 or less. Was fine after that though, until now. I will test for sync and voltage and report back
post #9 of 11 Old 10-07-2013, 08:17 AM
When mine did that It was
My High pressure oil pump went truck would run on a rag soaked in wd 40 help over air cleaner but wouldn't start without
1977ducati is offline
post #10 of 11 Old 10-07-2013, 03:57 PM
msmith's Avatar
Quoted: 7 Post(s)
Since your alternator went out and you drove on batt for a while, I am guessing that you killed your batteries. Take them off and have them tested and charged. They can have enough amperage with the two of them to crank normally but not enough voltage to power the computer to fire the injectors. Give it a shot, it's cheap if it fixes it and it can't hurt anything.
Mike aka Lineman
AUT VINCERI AUT MORI
as for me and my house, we will serve the LORD. Joshua 24:15 KJV
2015 F350 CCSB FX4
2007 Dark Stone F-250 CCSB Lariat 4x4, SOLD
20" Mastercraft Courser AXTs
CCV reroute
Edge CTS
PMM coolant filter
Diamond Eye 4" turbo back
SCT X3 w/Looney tune
Vision Diesel Stage 1 turbo
msmith is offline
