Help wierd symptom - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-01-2013, 05:29 AM Thread Starter
Help wierd symptom
Ok guys so out of nowhere I am driving doing about 45 and stopping at a light when I accelerate and take off, I get to about 40mph and the trans doesnt shift it just sits at 1900rpm and the boost rises to about 9psi. The truck feels as if it is trailering a load. you let off the gas and it slows down much faster then it normally does. I take off at the next light and it doesnt do it. then the next light i take off from it does the same thing again. What is going on? truck has 29,500 miles. I dont think the trans fluid has been changed so could this be it? would like to get this figured out asap as im towing a friends car to to a local drag strip for a event.
Thanks
Fabbed5.0 is offline
post #2 of 3 Old 10-01-2013, 05:52 AM
Check your fluid level. Have the truck scanned by ford. Not all aftermarket scanners can read tranny codes.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 10-01-2013, 06:41 AM Thread Starter
Fluid level is full, Ill call ford
