Rough run on custom tune, Bogging. HELP!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-27-2013, 01:50 PM Thread Starter
Hey guys, new to the forum. Hopeing someone can help me out with the problem I'm having.
2003 F-350 crew cab
240kms
Sct Livewire ts 5015, IDP extreme street tune
4 inch turbo back straight pipe
Blue Spring Upgrade
Just noticed this problem I'm having recently, while running my Extreme street tune. This problem is happening at dead stop acceleration, and rolling acceleration. Best way to describe how it sounds is a muffled exhaust bogging ( under water ) you can also feel it. Once you put your foot into it, turbo spools and bog goes away. This is only happening while running custom tune, can't notice this problem on stock or any other tune. If anyone has any ideas on contributing factors or problems that would be much appreciated, thanks.
BuiltBody is offline
post #2 of 8 Old 09-27-2013, 02:18 PM
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
WELCOME to the ORG!
I'd go back to the tuner and have them tweak the tune for you. I have a lot of tunes and some are AWESOME and some do what you describe. Some do a combination of being awesome and then bogging. Not all tunes work perfect without having some work for your rig done to them.
'05 F250, CC, FX4, 6.0 PSD
sct x4
MTW Stage 1 Turbo
DJ's FUEL+ - Fuel Pressure Intensifier
Nitrous Express NXd Stacker
Snow Performance Stage III Water/Meth Kit
ARP Studs
MBRP 4" Turbo Back w/ no Muffler & no Cat
DashBoss on my iPad
ISSPRO Gauges in Triple A-Pillar
High Idle Mod
Iron Horse Front Bumper Replacement
12,000LB MileMarker Winch
2000Watt Power Inverter
Viper 5901 Remote Start/Alarm
Pioneer Avic-D3 Stereo/Nav
Train Horns!
Valentine 1
Velvet ride shackles
RockStars on 33's
Big azz dent from a blown tire.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #3 of 8 Old 09-27-2013, 02:38 PM Thread Starter
Thanks for the reply Rod, I have contacted them already. They didn't have a whole lot to tell me, my only concern is this tune didn't do this from the beginning. I've had it running on m truck since April, only just started doing this it seems.
post #4 of 8 Old 09-27-2013, 02:42 PM
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
Oh. Well a lot of us have noticed that over times the tunes "seem" to loose some of the kick. Generally we've just tuned back to stock for a few days and then tuned back up and it seems to go back to normal kick azz. I thought it was just me but other 6.0 owners on here have said they do the same.
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #5 of 8 Old 09-27-2013, 03:01 PM Thread Starter
Unfortunately I have tried that,just drove for a week and switched back. Didn't make a change, worse than ever. But can't notice on other tunes, hopefully maybe it's just my tune? Could be something starting to go in my truck, and only noticing it under cranked HP tunes.
post #6 of 8 Old 09-27-2013, 03:10 PM
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
Hmmm. Strange. I'm sure someone more Tech savvy than I will chime in and help.
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #7 of 8 Old 09-28-2013, 06:55 AM
Soledad's Avatar
Garage
I'm actually having the same problem but in reverse and by that I mean when I return to stock I get the bogging from a dead stop or rolling acceleration. But, if I install one of my custom tunes the truck works perfectly. My thought is that my stock tune on the SCT got corrupt. And I think it happened when I tried to update the firmware on the SCT without going back to stock before doing it. Luckily I saved my stock tune before I did any updates or installed my first custom tune so I'm going to try and copy the stock tune back to the SCT and see what happens.
Maybe you need to wipe that tune from the tuner and then reload it from the PC/laptop?
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #8 of 8 Old 09-28-2013, 07:23 AM Thread Starter
Thanks for the reply Soledad, what you just stated makes total sense. Not that long ago I updated my Sct, iv heard nothing but bad things from the update. Just didn't expect to be seeing problems myself, I updated my Sct while on a tune I believe... Could also be contributing. I think I should try what you said, I'm gonna get IDP to send me another tune and I'll reload the new one onto my device. This way I can cancel out my tunes as being a problem, resolving I have a mechanical problem.
Thanks
