FICM/INJECTOR - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-26-2013, 09:48 PM Thread Starter
SAILOR97's Avatar
FICM/INJECTOR
OK question for you guys. I have a bad #2 injector so I'm getting ready to pull all 8 and send them to warren for a rebuild. Anyways as I started the truck to turn it around and park it in a position to pull the injectors my edge warning alarm was going off for the FICM voltage, it was at 38.5. So I let it idle and the voltage finally started to rise and reached 46.5. Now I'm curious would a bad injector cause this voltage loss in the FICM or is it just a coincidence that I need a new FICM...it sucks cause its more money...but if I need a new FICM what do you recommend...I want to bullet proof my truck for fuel economy and more horse power...so in other words a nice split between the 2. I'm gonna start running 5w-40 synthetic with rev-x additive with fuel bomb hellfire as an additive for the fuel which after all the awesome PM's about the oil I would like to get y'all's opinion or fact on this
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
post #2 of 14 Old 09-27-2013, 03:26 AM
Quoted: 50 Post(s)
More than likely your failing FICM took out your injector. Yes, definitely switch to a good synthetic 5w40 oil. Rev-x also works great to cure stiction, but if the injector has already gone south Rev-x will only help if the issue is on the oil side. You should also check fuel pressure. If it's too low (below 45 psi @ wot) injectors will be damaged on the fuel side. Rev-x won't fix this kind of failure.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 14 Old 09-27-2013, 08:44 AM
Term3's Avatar
I'd get your alternator and batteries checked out. The OEM alternator is undersized for our trucks. Also good idea is to upgrade the battery cables to something like 1/0 and clean your grounds down to bare metal. Low voltage going to the FICM is THE biggest killer of them.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 14 Old 09-27-2013, 09:49 AM
Quoted: 50 Post(s)
Exactly ^^^. It's an unfortunate trickle down effect.
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #5 of 14 Old 09-27-2013, 11:04 AM Thread Starter
SAILOR97's Avatar
Ok thanks guys..truck is gonna be tore apart for awhile now anyways and will look into those issues as I am pulling all 8 injectors and having them sent to Warren for rebuild. I will check these other issues too. So you all DO think I have a bad FICM now? FICM was 47-48 till this injector went south
SAILOR97 is offline
post #6 of 14 Old 09-27-2013, 11:07 AM Thread Starter
SAILOR97's Avatar
oh and just to add one thing my monitor is showing approx 13.8V so that should mean the Altenator and batteries should be ok right???
SAILOR97 is offline
post #7 of 14 Old 09-27-2013, 11:19 AM
Term3's Avatar
Not necessarily. Most important is what the voltage is under LOAD. An alternator can still produce proper voltage at low loads even with some bad diodes but put a heavier load on it and the voltage dies off fast. A bad battery can still indicate proper voltage but if its all sulfated up then under load it craters.
Term3 is offline
post #8 of 14 Old 09-28-2013, 03:18 PM Thread Starter
SAILOR97's Avatar
Term3 with that being said do I need to pull the batteries and go get them checked and same with the alternator. I just got the driver side injectors pulled and just finished placing the order for BPD FICM...this is hurting the pocket book...lol...I wanna know where my bail out is..hahaha
SAILOR97 is offline
post #9 of 14 Old 09-28-2013, 06:26 PM
Term3's Avatar
Yes, you could get your alternator and batteries load tested but if the batteries are few years old personally I'd buy a good pair of batteries such as Odyssey and a higher amp alternator because the OEM is plain and simple not even close to doing the job IMO. What you spend now will save you big time down the road.
Term3 is offline
post #10 of 14 Old 09-28-2013, 07:27 PM Thread Starter
SAILOR97's Avatar
How high of an amp alternator? Cause darn it with all this money I'm spending on injectors and FICM and everything else I don't want to be doing it again for a long time...lol...its why I went with warren rebuild and BPD FICM...lol
SAILOR97 is offline
