bad ficm symptoms but good ficm - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-26-2013, 09:34 AM Thread Starter
i have a 04 f 350 i bought about a month ago and i changed the oil and the fuel filters, i unplugged the battery to clean some corrosion off, since then i have had the rough start and idle like the symptoms of a bad ficm and i had a p0611 ficm code so i took the ficm off and sent it to ficm fixer in texas and they tested it and it tested good with 58 v on cold and 57.5 on crankin and running so i put that back on and i had a bad battery on the passenger side so i replaced both and no change in starting. it is a very rough start and idle till it warms up, lately its been 48f outside so not too cold. I need help guess im furious this happened and i havent had it very long, with no warrenty
04 f350
182000 miles
all stock
Diesel_trucker is offline
post #2 of 8 Old 09-26-2013, 10:12 AM
kraker829's Avatar
What kind of oil and filters did you use?
kraker829 is offline
post #3 of 8 Old 09-26-2013, 10:29 AM Thread Starter
motorcraft filter and 15w 40, and i ran about 5 qts shorts bc advanced ****ed up and told me 10 qts instead of 15 but it never shut off on me or anything, then i added the other 5 qts but no difference,
post #4 of 8 Old 09-26-2013, 04:31 PM
portcity_gt's Avatar
Quoted: 1267 Post(s)
Sounds to me like you need to try rotella t6 oil and rev x
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #5 of 8 Old 09-26-2013, 04:35 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Dang Portcity gt beat me . I agree 100%. You will see a big difference with the t6 but Id say check out archoil. Cheaper and do's a great job. (you can tell the portcity is one of those guys with money to burn.....just look at his pic for the love of god.....)
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 8 Old 09-28-2013, 06:13 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Archoil didnt do a whole lot for me. Revx was night and day difference in smoothness and quietness of the engine... But thats opening a different can of worms lol... OP- you need to get a monitor for your truck, especially if you plan on diagnosing or repairing yourself. There could be more going on than you think. If your truck died once or twice after a cold start you could have a bad hpop, air leak in fuel system, etc.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #7 of 8 Old 09-29-2013, 06:11 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Could not agreee with the above more. The monitor is a must have tool with the 6.0.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 8 Old 10-05-2013, 12:20 PM Thread Starter
well it doesnt start then die, i just keep turning it over and over till it fires up, if im trying to turn it over and let off the key it dies
