low battery - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-25-2013, 10:46 AM Thread Starter
low battery
i had a low battery on my passenger side, it was corroded on the positive termenal, would that give me a bad ficm code and would it make it sound like a bad ficm
Diesel_trucker is offline
post #2 of 4 Old 09-25-2013, 11:54 AM
Quoted: 50 Post(s)
It certainly can. Also, batteries need to be changed in pairs or you will quickly be replacing one, then the next, over and over.
I would change both batteries, check and clean all cables/terminals, clear the FICM code and then monitor FICM main power for a while. It should never go below 46v. If it does you need to get it repaired or replaced.
I would also confirm the alternator is working properly after battery replacement.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 4 Old 09-25-2013, 12:25 PM Thread Starter
well i sent the ficm in to get repaired bc of that code, and the place i sent it too called and told me that it tested good koeo and while cranking and running and i guess i have the 58 v ficm, then i tested both batteries and one showed good the other showed charge required, but ill replace both just in case
post #4 of 4 Old 09-26-2013, 03:24 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Replace both with quality batteries.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
