Long cranking time only when cold. Normal starting time when hot. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-24-2013, 11:17 PM Thread Starter
Paulliewog's Avatar
Been having trouble starting my truck after about 5 hours shutdown. I do know I have one bad glowplug, but even when it is warm out, it takes about ten seconds to begin to fire. Sometimes I have to hold the starter engaged while it initially fires until it gets going. Yes I know this is not good and as such I need help. Any ideas??
'05 F-350 King Ranch, lost the muffler.
can't find my cat???
SCT tuner, 58V Bulletproof Diesel 6 phase FICM upgrade
Paulliewog is offline
post #2 of 4 Old 09-26-2013, 05:38 PM
make sure your using the factory oil filter cap with a factory filter. I see this all the time on trucks coming into our shop. If your using the right cap and filter than air test it I bet with your truck being an 05 it's the STC fitting or a dummy plug.
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #3 of 4 Old 12-11-2013, 11:58 PM Thread Starter
Paulliewog's Avatar
OK, I am not sure about how to diag this, I don't have access to a good scan tool.
When i try to start it cold it takes about 10 seconds to start. After that if I don't drive it for at least a half hour, it still takes some time to start. Now being around 20 deg F. It takes several times to start and keep it going. After about 3 or 4 times it will stay running, don't know, is there a way to air test the hipop system without a scan tool??
post #4 of 4 Old 12-12-2013, 05:49 PM
Stc fitting or stand pipes. Mine did the same thing but to be sure you need to check icp? I believe. Someone else should chime in. I would go ahead and replace the stc fitting, $50 and then u know you wont have that weak link.anymore. took me just at 3 hours to do. Just pull the turbo and you can get to it. Kinda tight and far back there tho.
05 F250 4x4 cc sb Lariat: ARPs, zoodad, blue spring, sinister egr delete, banjos, sinister coolant filter, sct livewire with gearhead tunes; vivians looney on backup, leveled on 35" toyo mts, ranchhand legend front bumper, rotella T6, new oil cooler, zerex elc
troger11 is offline
