Unplugged battieres - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-24-2013, 02:54 PM Thread Starter
Unplugged battieres
I bought this truck and wanted to clean it up so i took the battery out to clean it i was just wondering if i would have tp get it reflashed bc since then and a oil change and fuel filter change and since then ive had nothing but problems, i got a p0611 code for the ficm and i sent it to a place who rebuilds then and they tested it and it tested great, jw if anyone has ran into this
Diesel_trucker is offline
post #2 of 9 Old 09-24-2013, 09:52 PM
Sno-Mow's Avatar
I always get the FCIM code when a battery is junk. Check your batteries amd alternator. A failing alternator will kill batteries.
I've just come to the conclusion that with plowing I generally need to put batteries in every winter.
Always replace batteries in pairs even if one checks good, the other is likely on its way out too.
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
post #3 of 9 Old 09-25-2013, 08:34 AM Thread Starter
both batteries check out good, will they check out good if still plugged up to the truck?
post #4 of 9 Old 09-25-2013, 11:47 AM
Quoted: 57 Post(s)
You can leave them in the truck but you must remove the cables before testing each one. Only way to accurately test them.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 9 Old 09-26-2013, 01:24 PM Thread Starter
well i had a bad battery on thye passenger side, i replaced both and went to start it this morning and the same thing, the ficm is good and 2 brand new autocraft gold batteries, im so lost, it sounds k=just like a bad ficm but its good
post #6 of 9 Old 09-26-2013, 01:43 PM
ZMANN's Avatar
Quoted: 1472 Post(s)
i have that code everyday and have a 100 percent good charging system and FICM
mine is caused by a 58 v FICM the code is for over voltage on mine
We Miss you Ronnie
ZMANN is offline
post #7 of 9 Old 09-26-2013, 05:32 PM Thread Starter
so the 58v pulls that code? thats what mine is
post #8 of 9 Old 09-30-2013, 07:39 PM
ZMANN's Avatar
yup guaranteed
not an issue
We Miss you Ronnie
ZMANN is offline
post #9 of 9 Old 10-02-2013, 07:56 AM Thread Starter
okay but I still dont get why im.having this problem, I had a bad egr flow and I put a new egr valve on it, I had a hole in the turbo cuppling replaced it, 2 brand new batteries new oil and fuel filters abd 8 brand new glow plugs and im still having the problem.where its a rough start for the veryyy first start of the day then.it starts and runs fine when its warmed up. im lost, the ficm.isnt bad.
