Oil Pressure Switch - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-23-2013, 10:17 PM Thread Starter
KCCO!!
kells17's Avatar
Oil Pressure Switch
All,
In the middle of putting on BPD Oil Cooler and when I removed old oil cooler, I noticed the electrical wire for the oil pressure switch on top of the oil cooler had been severed. When did this happen, dunno? Out of curiosity, how does this effect the performance of the rig, I haven't had any performance issues at all.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #2 of 9 Old 09-24-2013, 07:38 AM
Without knowing your oil psi is at least ok theres a risk you could keep running it with no oil. The wiring doesnt even go to the ecm, just to the dash.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #3 of 9 Old 09-24-2013, 07:42 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Technically you can't run a heui engine without oil, right?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 9 Old 09-24-2013, 08:43 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 120 Post(s)
Feedback Score: 7 reviews
without oil there is nothing to open the injectors. so if you run out of oil, the truck shuts off.
resplice it, its for a dummy light i think.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #5 of 9 Old 09-24-2013, 08:46 AM
PowerStrokeEnginuities's Avatar
WHS, no oil, no hydraulic, no start.
size="5">KEEP STROKIN
IF YOU DONT STAND BEHIND OUR TROOPS, FEEL FREE TO STAND IN FRONT OF THEM.
Proud U.S. Marine VET!
PowerStrokeEnginuities is offline
post #6 of 9 Old 09-24-2013, 01:56 PM
Quoted: 8 Post(s)
WHS???.....what's that?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 9 Old 09-24-2013, 02:03 PM
"What he said"
post #8 of 9 Old 09-24-2013, 06:46 PM
Oil cooler and hpop resevoir hold about 3-4 quarts, plus you could always have less that the 5-7 psi that the switch turns off at. My estimates say that this would possibly keep your engine running just long enough to melt your crank to your bearings. Will it affect the engine? No, could it possibly prevent you from needing a new lower end should you be paying half decent attention to your gauges? Yes.
Nows the perfect opportunity to justify buying a set of gauges to your wife. Get trans, and egt while your at it.
468 HP & 873 Ft-Lbs
ARP Head Studs
K&N CAI
Updated:
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #9 of 9 Old 09-24-2013, 09:20 PM Thread Starter
KCCO!!
kells17's Avatar
Thanks gents...i pay close attention to my gauges...never had a cel or trouble code pop on the cts...already ordered the part to have it fixed so i can button her back up. I check fluids religously also for peace of mind, and have trans, egt, turbo along with the cts already set up, just thought it was weird...
VA Strokers
757 Diesel
kells17 is offline
