MAP Sensor? Turbo? No power? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-19-2013, 04:48 PM Thread Starter
Ok my check engine light is on and has been for a week. Keeps throwing P0238 Turbo circuit A too high? Any idea what that means? The problem ive had but only happened once was I went to take off and it wasnt building much boost, had no power and the tranny wasnt shifting properly. Is it all due to the faulty what i assume faulty MAP sensor? Any ideas???
2003 F-250 6.0-95k miles-Edge juicew/att-Banks ram air system-straight 4in-
dirtydiesel007 is offline
post #2 of 6 Old 09-20-2013, 01:56 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Sounds like the vanes in your turbo might be stuck open. Can you monitor VGT cycle%?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 6 Old 09-21-2013, 07:05 PM Thread Starter
No I can't. I ordered a new MAP sensor and replaced the old one. Cleaned out the MAP tube and buttoned it all back up. No codes. Haven't had any power issues either. Hopefully that fixed it all. If not, my next thing is to pull turbo and have it cleaned out real good.
post #4 of 6 Old 09-22-2013, 04:08 AM
Also check your ebp sensor and tube are clean and clear. Those 2 sensors are the most common cause of your symptoms.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 6 Old 09-24-2013, 09:00 PM
Sno-Mow's Avatar
CAC tube leaks can cause it too
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
post #6 of 6 Old 10-01-2013, 03:56 PM Thread Starter
slapped a new MAP sensor in and cleaned MAP sensor tubes, deleted codes. No trouble, no SES.
