2006 ford f350 with a no start - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-19-2013, 04:36 PM Thread Starter
I have been working on this truck for a week now I have put in a hoop a new egr a new set of dummy plugs and a regular oil pump What else's can it be
Rrags82 is offline
post #2 of 7 Old 09-19-2013, 04:45 PM
bondsman's Avatar
Check for any codes. Get a monitor on there to see what your icp and ipr values are. Are you getting any oil pressure on the gauge while cranking? How is the ficm voltage? Make sure all three connectors are fully seated on the ficm. Hell, a bad ground can cause a no start.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #3 of 7 Old 09-19-2013, 04:50 PM Thread Starter
There are no codes ficm is at 48 but I am not getting oil to the injector rails
Rrags82 is offline
post #4 of 7 Old 09-19-2013, 05:01 PM
bondsman's Avatar
Sometimes you have to crank like crazy on it to get the air out of the system. Mine took forever and eventually it fired after I disconnected the icp sensor and ran it for a bit.
bondsman is offline
post #5 of 7 Old 09-19-2013, 05:05 PM Thread Starter
What about the oil not coming up to Injector rail
Rrags82 is offline
post #6 of 7 Old 09-19-2013, 05:15 PM
bondsman's Avatar
It gets there by cranking. The hpop sends it there. You have to get the air out of the system (by cranking). Mine killed two sets of batteries cranking on it. You have to just hold the key for a really long time (30 seconds is a long time to turn it over). Let the starter cool and do it again. It will fire up eventually. After we do head gaskets on a truck and go for a crank, the engine just sounds like it jas no compression. Once the oil fills the rails it will fire off.
bondsman is offline
post #7 of 7 Old 09-19-2013, 07:43 PM
jtaylor75's Avatar
Make sure you are building low oil pressure before trying to chase a high pressure issue.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
